varible dial/knob question
Nick
PostPosted: Tue Aug 24, 2004 8:23 pm     Reply with quote
I want to have a varible dial, I thinking many a pot attached to an analog pin and read it that way.. What are some other ways?
Nick
Yashu
Re: varible dial/knob question
PostPosted: Tue Aug 24, 2004 8:41 pm     Reply with quote
Nick
quadrature optical encoder
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed Aug 25, 2004 9:34 am     Reply with quote
... or a Hall effect encoder, or a mechanical encoder.
PostPosted: Wed Aug 25, 2004 10:39 am     Reply with quote
I guess the answer depends on what sort of control & feel you're looking for.
If you want something cheap and can spare two pins of port b (b4 - b7), then a mechanical encoder is the way to go. For example, see: http://ca.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=96152&Row=342823&Site=CA
To use something like this, just connect the two outputs directly to two pins on port b, enable the b pullups, and use the interrupt-on-change to detect when the encoder was turned. The drawback? It might not feel very "fine" to the user (i.e. relatively large turn required before something changes).
A pot only requires one analog pin, but it may be noisy. Another thing to consider is that the large "front panel" type of pot you'd need tend to be pricey. They also tend to get dirty with age. I'm reminded of the old car radios that would crackle badly whenever you touched the volume knob.
Nick
PostPosted: Wed Aug 25, 2004 10:43 am     Reply with quote
perfect, thanks for that link!
Nick
