young
| NetMedia 2X16 LCD |
Posted: Wed Aug 18, 2004 2:15 pm |
Anyone has used NetMedia 2X16 LCD using CCS. I currently have one , and I want to use it, but do not know how. It just use one wire communication RX. but I could not get it work. here is my program
#if defined(__PCM__)
#include <16F819.h>
#use rs232(baud=9600, parity=N, xmit=PIN_B7)
printf("Single wire LCD!");
young
Posted: Wed Aug 18, 2004 2:48 pm |
| It is a serial LCD, any suggestions or code please? |
Posted: Wed Aug 18, 2004 3:00 pm |
Well how about using Google ?
If I go to Google, and search for NetMedia 2X16 LCD, I get the manual for the device:
http://www.basicx.com/Products/SLCD/ser2x16.pdf
I also get sample code for Basic Stamp 2, from Peter H. Anderson,
a well-known professor in the Pic community.
http://www.phanderson.com/basicx/lcd_2x16_bs2.html
By studying that code, I can see that before he uses the LCD,
he calls two routines:
LCDSetGeometry
and
LCDReset
When I look at those routines, I see that they use the Serout command.
I can see that it uses 9600 baud, so I know to set my #use rs232()
statement in CCS for 9600 baud also.
I can see that the LCDSetGeometry function has 6 data bytes that must
be sent: 15, 16, $80, $c0, $80, $80
So I could do this by using the CCS putc() command, because it sends
a single byte out the RS232 pin. Like this:
putc(15);
putc(16);
putc(0x80);
putc(0xc0);
putc(0x80);
putc(0x80);
For LCDReset function, I must send one byte (14), and then delay
for 1000 ms. So this would work:
putc(14);
There may be other details that are important. You can use Google
to find more documents on the LCD and study them. |
John Morley
Posted: Wed Aug 18, 2004 3:04 pm |
Also, are you sure you've connected to the pin you specify in your code, and are you sure the connections to the LCD are correct? Do you have a scope to put on the data output pin from the PIC to see if any data is being sent??
John _________________ John Morley |
young
Posted: Wed Aug 18, 2004 3:41 pm |
I saw the code in Basic, and am trying to undertstand it. If there is already one sample, it will be great.
I believe that I connected pins correctly.
I will try to find it out, anyway! |
young
Posted: Wed Aug 18, 2004 4:07 pm |
what does
sewrout TXPin, N9600,10, [12]
number 10 means?
is it right if I define function as
void LCDSetContrast(int8 contr)
putc(10);
putc(contr);
Posted: Wed Aug 18, 2004 4:25 pm |
If you use Google, and type in SEROUT, then you get this as the
top link:
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv16.pdf
It tells you the format of the Serout command:
Serout tpin, baudmode, {pace,} [output data]
It says the "pace" parameter is the number of milliseconds
between characters. So, if your example has "10", then
that's a 10 ms delay. You can do this with CCS like this:
putc(12);
delay_ms(10);
If you have several characters for "output data", then
put a delay_ms(10); statement after each putc() statement.
This will do the same thing as the Serout command. |
young
Posted: Wed Aug 18, 2004 4:38 pm |
Thank you very much
as of my code
LCDSetContrast: 'value is passed in x
SerOut TxPin, N9600,10, [19,x]
return;
right if I convert it to c as
void LCDSetContrast(int8 x)
putc(19);
delay_ms(10);
putc(x);
delay_ms(10);
is putc(x) correct?
Thank you
Posted: Wed Aug 18, 2004 5:06 pm |
| Yes, it looks like you have properly translated the Basic Stamp 2 function to C. |
young
Posted: Wed Aug 18, 2004 5:18 pm |
Thank you:
I put this together for a test, but I hust see "||||||||||" on my screen. what might happened?
#include <16F819.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP
#use delay(clock=8000000)
#use rs232(baud=9600, parity=N, xmit=PIN_B7, rcv=PIN_B6) // Jumpers: 8 to 11, 7 to 12
//#include <lcd420_1.c>
//#include <math.h>
void LCDSetGeometry();
void LCDReset();
void LCDinit();
void LCDSetBackLight(int8 backlit);
void LCDSetContrast(int8 contr);
void LCDClrScr();
void LCDNewLine();
void LCDCR();
void LCDTab();
void LCDVerTab();
void LCDBackSpaces(int8 bspa);
void LCDSetTab(int8 Stab);
void LCDSetCursorPos(int8 x, int8 y);
void LCDClrLine(int8 x, int8 y);
void LCDSetCursorStyle();
void LCDOnOff(int8 onoff);
LCDinit();
LCDClrScr();
puts("Serial LCD");
putc(15);
delay_ms(10);
putc(16);
delay_ms(10);
putc(0x80);
delay_ms(10);
putc(0xc0);
delay_ms(10);
putc(0x80);
delay_ms(10);
putc(0x80);
delay_ms(10);
void LCDReset()
putc(14);
void LCDinit()
// Set LCD Geometry
LCDSetGeometry();
// LCDReset
LCDReset();
void LCDClrScr()
putc(12);
delay_ms(10);
Posted: Wed Aug 18, 2004 6:01 pm |
| Quote: | | I put this together for a test, but I hust see "||||||||||" on my screen. what might happened? |
Are you using a MAX232 type of RS232 level translator chip between
the Netmedia LCD and your PIC ?
I suspect that you are not.
On page 3 of the LCD manual,
it shows the LCD Rx pin is connected directly to the PC RS-232 connector.
To emulate this with a software USART in the PIC, you need to use
the INVERT option. You should add it to your #use rs232() statement,
as shown in bold, below:
#use rs232(baud=9600, parity=N, xmit=PIN_B7, rcv=PIN_B6, INVERT) |
Posted: Thu Aug 19, 2004 6:22 am |
Thank you PCM:
I just came back to work. I will work on it till I solve.
I put the "INVERT" there, but still not signal at all. |
Posted: Thu Aug 19, 2004 6:30 am |
| and My chip become so hot, I am afraid it burned. but I still have several spare one. I will keep trying. |
Posted: Thu Aug 19, 2004 6:48 am |
| When I remove Invert, the ||| bar comes back again, When I use INVERT it becomes hot. Do you think I should use RS232 to try, I will and let you know. |
Posted: Thu Aug 19, 2004 9:52 am |
| I connected RS232 between 16f819 and LCD RX, just some strange character, mostly japanese character., Any suggestions? |
