Problems reading DS1307
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Aug 24, 2004 1:55 pm     Reply with quote
Colleagues,
When reading from DS1307 RTC I'm getting this artifact. Evey other packet I receive is identical and is also garbage. Could you take a look at the code and the output and tell me what's wrong?
Thanks,
Nick
#include "test13.h"
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(INT_RDA);
   printf("start\n\r");
      // writer the read address for the seconds register (0x00)
      do i2c_start();
      while (1 == i2c_write(0b11010000)); // poll for ack
      printf("wr ack\n\r");
      i2c_write(0x00);                    // seconds address
      // read the seconds from the RTC and output them to RS232
      do i2c_start();
      while (1 == i2c_write(0b11010001)); // poll for ack
      printf("rd ack\n\r");
      printf("0x%X ", i2c_read());      // read the seconds
      printf("0x%X ", i2c_read());      // read the minues
      printf("0x%X\n\r", i2c_read());     // read the hours
      i2c_stop();                         // end of transaction
      delay_ms(2000);
Header file:
#include <18F452.h>
// #device ICD=TRUE
#device adc=10
#use delay(clock=12800000)
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB //, LVP
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
Output:
0x51 0x54 0x20   // OK
0x03 0xFF 0xFF   // gardbage
0x55 0x54 0x20   // OK
0x03 0xFF 0xFF   // garbage
0x59 0x54 0x20   // OK
0x03 0x55 0x20   // OK, minutes change
Nick
PostPosted: Tue Aug 24, 2004 1:59 pm     Reply with quote
Have you hooked up your 3v battery? is the connection loose? Thats how I usually end up getting garbage over my DS1307. I even made a check for it to tell me what was the problem since I'm using a soldierless bread board and connections arnt that great.
Nick
PostPosted: Tue Aug 24, 2004 2:03 pm     Reply with quote
I didn't check your entire code in detail, but I see two things:
1. The last call to i2c_read(), in a series of calls, must have a 0
parameter. This does a "NAK" instead of an ACK. This is part
of the i2c specification.
Example:
i2c_read();
i2c_read();
i2c_read(0); // Last call does a NAK
2. If it was me, I would disable interrupts while doing the i2c operations.
kender
PostPosted: Tue Aug 24, 2004 2:04 pm     Reply with quote
My battery connection and battry voltage look OK. Also, both PIC and DS1307 are running of 5V regulator. I might be wrong, but I think that in this case the 3V battery doesn't have a lot of influence. Thanks for the tip though.
Nick
kender
PostPosted: Tue Aug 24, 2004 2:08 pm     Reply with quote
i2c_read(0) worked. The data is valid all the time now.
Thank you!
Nick
PostPosted: Tue Aug 24, 2004 3:15 pm     Reply with quote
IME, the DS1307 will not function at all without the 3V battery and the 32 kHz xtal connected. Glad you got it going though.
kender
PostPosted: Tue Aug 24, 2004 3:20 pm     Reply with quote
Well, I have just removed the battery without turning off 5V, reset the PIC, and DS1307 was outputing the correct data.
Nick
ximo
ds1307 driver
PostPosted: Thu Oct 07, 2004 9:03 am     Reply with quote
this is my driver for the ds1307 and function very good with 16f877a and 18f8720:
// first configure the i2c
#use I2C(MASTER, SDA=PIN_C4, SCL=PIN_C3, RESTART_WDT, FAST)
void get_rtc_time(){
   int i;
   i2c_start();
   i2c_write(code_escribe);
   i2c_write(0);
   i2c_start();
   i2c_write(code_escribe | 1);
   for (i=0;i<sizeof(rtc);i++)
      rtc[i]=i2c_read(i<sizeof(rtc)-1);  //rtc is a array with the read
   i2c_stop();
void set_rtc_time(){
   int i;
   i2c_start();
   i2c_write(0);
   for(i=1;i<sizeof(config);i++)
      i2c_write(config[i]);      //config is a array with the hour etc...
   i2c_stop();
[/code]
asmallri
PostPosted: Thu Oct 07, 2004 9:23 am     Reply with quote
Nick
That is just luck. When you actually try using it in the field it WILL crash. It is possible to use the DS1307 without a battery but in this case you need to pull the +battery input pin to ground via a resistor. It may also work pulling it to plus 5 but that is not how I use the device. The reason it will crash without this is because it is a smart little bugger. If it sees the battery pin is a higher potential that the +5v rail, it assumes the +5v rail is failing and shuts down all interfaces to save power. And guess what, sooner or later the +battery terminal will float higher than the +5V rail - maybe when a cat comes in the room, or it starts raining outside or just for the hell of it. It is dead easy to test. I spent three weeks chasing this intermittent crash problem.
Re: Problems reading DS1307
PostPosted: Thu Oct 07, 2004 10:05 am     Reply with quote
kender wrote:
Colleagues,
Thanks,
Nick
#include "test13.h"
   setup_adc(ADC_OFF);
      do i2c_start();
      do i2c_start();
      delay_ms(2000);
Header file:
#include <18F452.h>
// #device ICD=TRUE
#device adc=10
Output:
I have used the 1307, without problems, but have allways 'stopped' each transaction, rather than using a repeated start, and used the 'NACK', on the last byte before stopping. I use:
/* I2C address for chip, including direction flag */
#define CADDRWR   0xD0
#define CADDRRD   0xD1
#define NACK                    0
  I2C_START();
  WHILE (I2C_WRITE(CADDRWR));
  I2C_WRITE(0);      /* set address to 0 */
  I2C_STOP();
  I2C_START();
  WHILE (I2C_WRITE(CADDRRD));
  clock.secs=I2C_READ();
  clock.mins=I2C_READ() & 0x7F;
  clock.hours=I2C_READ() & 0x3F;
  clock.dayofweek=I2C_READ() & 7;      /* day of week */
  clock.dayofmnth=I2C_READ() & 0x3F;   /* day of month */
  clock.month=I2C_READ() & 0x1f;      /* month */
  clock.year=I2C_READ(NACK);      /* Year, and finish */
  I2C_STOP();
I suspect your problem is not using the 'NACK', on the last transaction. The data sheet, specifically says 'the DS1307, _must_ receive a NACK, to terminate a read'.
Mark
PostPosted: Thu Oct 07, 2004 10:18 am     Reply with quote
Note that this post is old and the guy solved his problem. Someone was just posting their driver code
PostPosted: Thu Oct 07, 2004 2:17 pm     Reply with quote
Yes.
For some reason, the post appeared at the head of the list as a single 'new' post (no 'driver code' visible), so I replied.
After I had replied, the 'hread' became visible.
I suspect there was a hiccup in the board somewhere.
