		| View previous topic :: View next topic   |
			Richard Guest
				| integrator output to drive a load |
				 Posted: Fri Aug 20, 2004 9:22 am     |
I have a problem,  I need to drive the output of an op-amp into a
DC bulb.
The bulb requires 100mA, at 6v maximum.
How do I provide the the exact same voltage from the opamp, but with more current?
I was thinking of a using a NPN transistor as a switch, but this would
only provide +vcc and 0v, I need all the voltages in between
Any links or thoughts
I am truly in a pickle |
				| Re: integrator output to drive a load |
				 Posted: Fri Aug 20, 2004 9:42 am     |
				 	  | Richard wrote: | 	 		  Hi,
DC bulb.
Get a power op-amp.
Look at devices like the LM675 (overkill for the power you need, but very good). Also consider some of the audio amplifier chips. For the low power you need, I'd probably look at the LM386, which is simple to use, and migh be able to replace your op-amp, and give the required output. This behaves rather like an op-amp, but with an internal feedback resistor that programs the gain. Provided your circuit does not need more gain than it provides, you can add an external feedback circuit and use it like an op-amp.
			SherpaDoug
				 Posted: Fri Aug 20, 2004 11:47 am     |
Consider using your NPN transistor as an "Emitter Follower."  You will lose a diode drop so for a op amp signal of 0 to 5V you would get 0 to 4.3V but this may be close enough and it is dirt cheap.  Simply connect the op amp to the NPN base through about 100 ohms.  Connect the NPN collector to +vcc.  Connect the bulb from the NPN emitter to ground.  Note that at worst case (half brightness) the NPN power dissapation could be 0.1A x 3V = 0.3W
The base resistor is needed to prevent VHF oscillations. _________________ The search for better is endless.  Instead simply find very good and get the job done. |
