Weekday alarm in PCF8583
otuzsubat
PostPosted: Wed Aug 11, 2004 7:34 am     Reply with quote
I want to use weekday alarm in PCF8583. For example, i want that it produces an interrupt at every Monday, 13:30. My code is below. Could you say me where is the mistake?
int int2bcd(int dec){
return ((dec/10)<<4)+(dec%10);
void rtc_set(){
i2c_start();
i2c_write(0xA2); //send device address
i2c_write(0x00);//send address byte
i2c_write(0x80);//Stop RTC counting
/*************Write actual time ****************/
i2c_write(0x00);//Hundredth of second
i2c_write(0x00);//Seconds
i2c_write(rtc[3]);//Minutes(in BCD format)
i2c_write(rtc[2]);//Hours(in BCD format, 24hour format)
i2c_write(rtc[0]);//Year/Date(in BCD format)
i2c_write(rtc[1]);//Weekday/Month(in BCD format)
i2c_write(0x00);//Disable Timer
/*************Write alarm time ****************/
i2c_write(0xA0);// Alarm Flag, Interrupt, No timer alarm, Weekday alarm
i2c_write(0x00);//Alarm Hundredth of second
i2c_write(0x00);//Alarm Seconds
i2c_write(int2bcd(alarm.minute));//Alarm Minutes
i2c_write(int2bcd(alarm.hour));//Alarm Hours
i2c_write(0x00);//Alarm Date
i2c_write((0x01<<(alarm.day-1)));//Alarm Weekday
i2c_stop();
delay_ms(5);
i2c_start();//start transmission
i2c_write(0x00); //send device address
i2c_write(0x00);//Send address byte
i2c_write(0x04);//Start RTC counting
i2c_stop();
delay_ms(5);
bdavis
PostPosted: Wed Aug 11, 2004 2:01 pm     Reply with quote
You are writing to two different device address's - one at the top, and the one near the bottom are different. Doesn't seem correct to me...
Kenny
PostPosted: Thu Aug 12, 2004 12:29 am     Reply with quote
Try poking some values directly into the registers for testing.
I tried the code below and it works. For testing 15 seconds is allowed till the interrupt occurs. The interrupt flag (bit 1 in control reg.) will need to be cleared after it occurs by writing the control byte again
write_rtc(0x00,0x04);
#define PCF8583_WRITE_ADDRESS 0xa0
   i2c_start();
   i2c_write(PCF8583_WRITE_ADDRESS);
   i2c_write(0x00);  // Control reg. (address 0x00), auto increment word address
   i2c_write(0x80);  // Stop counting
   i2c_write(0x00);  // Hundredths of sec.
   i2c_write(0x45);  // Sec.
   i2c_write(0x29);  // Minutes
   i2c_write(0x13);  // Hours
   i2c_write(0x16);  // Year/date Year = 0, date = 16.
   i2c_write(0x28);  // Weekday/month. Weekday = 1, month = 8
   i2c_write(0x00);  // Timer value. N/A for this case.
   i2c_write(0xa0);  // Alarm control. Weekday alarm, flag for interrupt
   i2c_write(0x00);  // Alarm hundredths
   i2c_write(0x00);  // Alarm secs
   i2c_write(0x30);  // Alarm mins
   i2c_write(0x13);  // Alarm hours
   i2c_stop();
   write_rtc(0x0e,0x02);   // Alarm on weekday 1 (Monday, assuming 0 is Sunday)
   write_rtc(0x00,0x04);   // Control reg, enable alarm, counting
   while(1);         // Or get and output date/time while waiting
// Writes byte to PCF8583 register
void write_rtc(int8 reg,int8 data)
   i2c_start();
   i2c_write(reg);
   i2c_write(data);
   i2c_stop();
otuzsubat
PostPosted: Thu Aug 12, 2004 2:49 am     Reply with quote
I made a typing mistake. I corrected it. But still don't work.
