Tool
PIC18F452 |
Posted: Wed Aug 11, 2004 2:32 pm |
I have researched this topic to no avail.
As you will probably discover I do not have much experiance with embedded programming and any help is much appreciated
I am having trouble initializing an LCD it is a
CrystalFontz - cfah1202a-yyb-jp it uses the Hitachi HD44780u Controller.
I am programming a pic18f452 and using the 4-bit 2-Wire LCD Interface found here http://www.rentron.com/Myke1.htm
PIN_C0 for Data and PIN_C1 for the clock
I beleive I am having trouble with the timing and a general understanding of "what" to send "when"
I have and read the datasheets for the pic18f452, Hitachi Controller, the LCD display and even the Motorola D-flip flop chip
DISCLAIMER: I did not write this
CCS Compiler Ver 3.42
Target voltage = 5V
Target oscillator speed = CPU_CLK 19660800
#define LCD_DATA PIN_C0
#define LCD_CLK PIN_C1
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
** LCD_Write_Nybble: Write the lower 4 bits of Argument Nybble to the LCD (via a 164 shift register 2 wire interface)
static void LCD_Write_Nybble(BYTE Nybble, BYTE RS)
unsigned char i;
output_low(LCD_DATA); // Clear the '164
for (i = 0; i < 6; i++) // Repeat for six bits
output_high(LCD_CLK);
output_low(LCD_CLK); // Write the "0"s into the '164
output_high(LCD_DATA); // Output the "AND" Value
output_bit(LCD_DATA,RS); // Output the RS Bit Value
for (i = 0; i < 4; i++) // Output the Nybble
if ((Nybble & 0x08) != 0)
output_high(LCD_DATA); // Output the High Order Bit
output_low(LCD_CLK); // Strobe the LCD_CLK
Nybble = Nybble << 1; // Shift up Nybble for Next Byte
output_low(LCD_DATA); // Toggle the "E" bit of the LCD via gating circuitry
} // End LCDNybble
void lcd_send_byte( BYTE address, BYTE n ) {
LCD_Write_Nybble(n >> 4, address);
delay_cycles(64);
LCD_Write_Nybble(n & 0xf, address);
delay_cycles(64);
void lcd_init() {
BYTE i;
delay_ms(500); // 15
for(i=1;i<=3;++i) {
LCD_Write_Nybble(0x03, 0);
delay_ms(20); // 5
LCD_Write_Nybble(0x02, 0);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
void lcdPutString(char *msg)
int i;
for(i=0; msg[i] != '\0'; i++)
lcd_putc(msg[i]);
The main calls the lcd_init() nothing changes and the black row on top remains.
My
Cheers,
Tool |
rnielsen
Posted: Wed Aug 11, 2004 4:24 pm |
I just looked at the spec sheet for the HD44780u controller and it looks like it uses a standard 4 or 8 bit interface, plus the RS, WR and E lines. Trying to talk to it via a 2 line clocked signal will not work. I suggest looking at the spec sheet a bit closer to make sure you have the right kind of bug that you think you have.
Ronald |
Posted: Thu Aug 12, 2004 2:28 am |
rnielsen wrote: | I just looked at the spec sheet for the HD44780u controller and it looks like it uses a standard 4 or 8 bit interface, plus the RS, WR and E lines. Trying to talk to it via a 2 line clocked signal will not work. I suggest looking at the spec sheet a bit closer to make sure you have the right kind of bug that you think you have.
Ronald |
He is not trying to talk directly to the interface with a two wire bus. If you look at the article he gives the link for, it uses a 18F84, to control a normal parallel LCD, and translates from a 2wire bus, which he is trying to drive.
The problem though is that there are so many places where this could fail, and without some test equipment, little advice we can give.
The way to proceed, will depend on what equipment is available, but ideally, he needs to be looking at whether the clock and data signals are being generated, and getting to the unit. Personally, I'd probably suspect that the translator unit is not working, and would look at writing some form of 'test code' to put into this, to verify that all the lines are operable.
The code as ritten, looks 'possible', for the interface described, but tracking down where the problem lies, is going to involve simplifying, to smaller component parts.
Posted: Thu Aug 12, 2004 6:12 am |
Thanks for the replies
I know the clock PIN_C1 and data PIN_C0 are fine, I have tested them with a scope and can change them high to low as I please.
I will write a little tester and try it step by step, as you suggest.
I have a funny feeling it is just a timing issue, sending the wrong nibble at the wrong time.
I'll keep ya posted, because I have noticed not many people have deployed this interface, save a lot of pins...  |
Tool
Posted: Thu Aug 12, 2004 6:30 am |
Sorry I am at work and forgot to log in before posting...  |
Tool
Posted: Thu Aug 12, 2004 12:55 pm |
Just to close this thread, I examined the back of the lcd and the data lines are on pins 12,13,14,15.........whoops
they should be on pins 11,12,13,14...15 is for the backlight
this is what happens when you are thrown into a project and assured all hardware is wired correctly  |
rnielsen
Posted: Thu Aug 12, 2004 1:28 pm |
Now you know why Engineer's foreheads are always flat.
*Bangs head against wall*  |
