SIOW watch window logging....
pctprogrammer
PostPosted: Fri Aug 06, 2004 2:06 pm     Reply with quote
Question:
I noticed that with the CCS softwares SIOW watch window it has an option for 'data logging'. After playing around with this I became stupified with where this data Im logging is going. Does anyone know where this information is being stored? I tried opening up a file prior to logging and all that fun stuff.
Thanks.
mkent
PostPosted: Sat Aug 07, 2004 12:18 pm     Reply with quote
Go to the configuration menu pulldown, click on logging (if it is grayed out you must un-check log to file under "File") and set the path in the filename window. This allows a much larger file to be saved than is allowed in the SIOW window. Mick
