Nick Guest
| Do nanowatt pic chips program differently? CCS Supported? |
Posted: Fri Aug 06, 2004 12:01 pm |
I am currently using a pic16f876, since i will be going to battery driven I'm looking at the picf16737 (nanowatt). My JDM programer does not show it supported and the CCS compiler doesnt have a 16f373.h file just a 16f73.h
Does anyone know if the 16f73.h file will work? Also anyone has with a jdm style programmer programmed 16f737?
Nick |
Posted: Fri Aug 06, 2004 12:16 pm |
| Quote: | | the CCS compiler doesnt have a 16f373.h file just a 16f73.h |
I'm using PCM vs. 3.188, and it has it:
| Quote: |
Directory of C:\Program Files\PICC\Devices
16F72 H 7,035 03-25-04 2:38p 16F72.h
16F73 H 7,476 03-25-04 2:38p 16F73.h
16F74 H 8,329 03-25-04 2:38p 16F74.h
16F76 H 7,476 03-25-04 2:38p 16F76.h
16F77 H 8,329 03-25-04 2:38p 16F77.h
16F716 H 6,343 03-25-04 2:38p 16F716.h
16F747 H 11,410 03-25-04 2:38p 16F747.h
16F767 H 10,744 03-25-04 2:38p 16F767.h
16F777 H 11,410 03-25-04 2:38p 16F777.h
16F737 H 10,744 03-25-04 2:38p 16F737.h |
Mark
Posted: Fri Aug 06, 2004 12:18 pm |
You mean this file:
//////// Standard Header file for the PIC16F737 device ////////////////
#device PIC16F737
#nolist
//////// Program memory: 4096x14 Data RAM: 367 Stack: 8
//////// I/O: 25 Analog Pins: 11
//////// C Scratch area: 77 ID Location: 2000
//////// Fuses: LP,XT,HS,EC_IO,NOWDT,WDT,NOPUT,PUT,PROTECT,NOPROTECT
//////// Fuses: NOBROWNOUT,BROWNOUT,INTRC_IO,INTRC,RC_IO,RC,BORV45,BORV42
//////// Fuses: BORV27,BORV20,MCLR,NOMCLR,CCP2C1,CCP2B3,DEBUG,NODEBUG,FCMEN
//////// Fuses: NOFCMEN,IESO,NOIESO,BORSEN,NOBORSEN
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
// PORT_B_PULLUPS(), INPUT(),
// OUTPUT_LOW(), OUTPUT_HIGH(),
// OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
Might need to update your compiler if it is not there. |
