a Guest
| Why not work |
Posted: Thu Aug 05, 2004 6:13 am |
when i use pin_c0 show led by this code but pin_c0 is light all the time.
but when i use timer0 for change value in pin_c1. Pin_c0 is not light all the time but it blink like pin_c0-->on and off.Why?
#include <16F877.h>
#device *=16
#device adc=10
#use delay(clock=4000000,RESTART_WDT)
#fuses NOWDT,XT, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#ZERO_RAM
#include<stdio.h>
#include<stdlib.h>
#include<math.h>
#include<string.h>
#define RS PIN_E0
#define RW PIN_E1
#define EN PIN_E2
#define leddison output_high(pin_c0)
#define leddisoff output_low(pin_c0)
char tmpshow[20];
int resetch1=0;
#int_TIMER0
TIMER0_isr()
if (resetch1==1)
output_high(pin_c1);
output_low(pin_c1);
int checkdisend=1;
long valueadc;
int sdis=0;
port_b_pullups(TRUE);
setup_adc_ports(A_ANALOG);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
// enable_interrupts(INT_TIMER0); <====when i comment this line it work but when i not comment this line it error.
// enable_interrupts(GLOBAL); <====when i comment this line it work but when i not comment this line it error.
set_adc_channel( 0 );
delay_ms(10);
valueadc = Read_ADC();
if (valueadc<=55)
resetch1=1;
resetch1=0;
if(!input(pin_b2))
checkdisend=0;
if( input(pin_b3)) //ถ้ายังไม่มีถ่านหรือว่า Discharge เสร็จแล้ว เป็น 1
output_low(pin_b4);
checkdisend=1;
leddisoff;
delay_us(10);
sdis=0;
else //ถ้า discharge ยังไม่เสร็จ เป็น 0
if(checkdisend==0)
output_high(pin_b4);
leddison;
sdis=1;
checkdisend==0;
leddisoff;
output_low(pin_b4);
checkdisend=1;
sdis=0;
Posted: Thu Aug 05, 2004 7:01 am |
checkdisend is always 1 so only leddisoff is called.
Maybe you'd want to write:
checkdisend=0;
instead of :
checkdisend==0;
in the "if(checkdisend==0) " branch. |
a Guest
| a |
Posted: Thu Aug 05, 2004 8:49 am |
thank you for your answer. But i recompile program. it have the same error. can i use pin_c0 and pin c1 seperate like output_high(pin_c0) or another but when i use c1. output of c0 is change it blink on off on off
but when i am not use pin c1. it ok pin c0 is light all the time until input(pin_b3)=1.
anyone can help me. Please. |
