display driver
Eldert Besseling
display driver
PostPosted: Mon Apr 26, 2004 4:37 am     Reply with quote
Hi All,
I am searching for drivers for the winstar WG12864F-YYH-V display
This is a LCD display with a character generator T6963C
Has somebody drivers written for it?
Regards
Eldert
treitmey
PostPosted: Mon Apr 26, 2004 10:20 am     Reply with quote
Yup, did this one too.
I wish we could have a file pile for code snipets and drivers.
Take it for what its worth. I'm not sure how complete it is.
I just mod a different graphics LCD driver.
//// c:\program files\PICC\drivers\LCD_T6963C.c                      ////
//// This file contains drivers for using a Tosiba T6963C controller ////
//// in parallel/8080(intel) mode.  The T6963C is 240 pixles across  ////
////  and 64 pixels down. The driver treats the upper left pixel 0,0 ////
////  glcd_init(mode)                                                ////
////  glcd_pixel(x,y,color)                                          ////
////  glcd_line(x1,y1,x2,y2,color)                                   ////
////  glcd_rect(x1,y1,x2,y2,fill,color)                              ////
////  glcd_bar(x1,y1,x2,y2,width,color)                              ////
////  glcd_circle(x,y,radius,fill,color)                             ////
////  glcd_text57(x,y,textptr,size,color)                            ////
////  glcd_fillScreen(color)                                         ////
#ifndef GLCD_COL
#define GLCD_COL 240    // Used for text wrapping by glcd_text57 function and sanity check
#endif
#ifndef GLCD_ROW
#define GLCD_ROW 64    // Used for text wrapping by glcd_text57 function and sanity check
#endif
#define ON  1
#define OFF 0
#define YES 1
#define NO  0
#define set_tris_lcd(x) set_tris_a(0);set_tris_d(x)
//TRIS DataBus=x,  note:control bus (PORTA) always outputs
////////////////////[PICK ONE OF THESE TWO SECTIONS]//////////////////
//const int1  LCDFont = 0;//Font select
//const int16 TextHome    =0x0780;
//const int8  AreaSet_T   =0x001E;//how many bytes before a new line
//const int16 GraphicsHome=0x0000;
//const int8  AreaSet_G   =0x001E;//how many bytes before a new line
const int1  LCDFont = 1;//Font select
const int8  AreaSet_T   =30;//how many bytes before a new line
const int8 AutoModeWrite=0xB0;
const int8 AutoModeRead =0xB1;
const int8 AutoModeReset=0xB2;
const int8 LCDModeSet  = 0x80;//send this OR'd with the following
const int8 LCDMode_OR  = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0010;
const int8 LCDMode_TA  = 0b0100; //TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; //1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr =0x21;  //Number of lines in the cursor
const int8 LCDSetCursorSize=0xA0;  //Number of lines in the cursor
const int8 LCDDispMode = 0x90;//send this OR'd with the following
const int8 LCDDisp_BLK = 0b0001;
const int8 LCDDisp_CUR = 0b0010;
const int8 LCDDisp_TXT = 0b0100;
const int8 LCDDisp_GRH = 0b1000;
const int8 LCDMaxBusyCount =20;//will try count-1 times before giving up
struct lcd_pin_def
  BOOLEAN w_bar;      // A0 Write bar active low
  BOOLEAN r_bar;      // A1 Read bar active low
  BOOLEAN ce_bar;     // A2 Chip Enable BAR active low
  BOOLEAN cd;         // A3 Command/Data BAR   1=command 0=data
  BOOLEAN reset_bar;  // A4 Reset active low
  BOOLEAN fs;         // A5 Font select
  BOOLEAN unused1;    // A6 Unused
  BOOLEAN unused2;    // A7 Unused
  int  unused4 :  8;  // PortB...  waisted some bits/bytes for clarity
  int  unused5 :  8;  // PortC...  waisted some bits/bytes for clarity
  int  data    :  8;  // PortD=Data bus
struct lcd_pin_def  LCD;
#if defined(__PCM__)
#byte LCD = 5    //(no semicolin) 5=A0 on a 16F877A
#elif defined(__PCH__)
#byte LCD = 3968    //(no semicolin)3968=A0 on a 18F452
#endif
void glcd_FontSelect(int1 fs);
BYTE glcd_ReadByte();
int1 glcd_WriteByte(int1 cd, BYTE data); //return, 1=success 0=failure
int1 glcd_WriteByteAuto(BYTE data); //return, 1=success 0=failure
int1 glcd_WriteCmd2(int16 data, BYTE cmd);
int1 glcd_WriteCmd1(BYTE data, BYTE cmd);
//BOOLEAN glcd_pixel(unsigned int x,unsigned int y, int1 color);
//void glcd_fillScreen(int1 color);
void glcd_init(int1 mode) //init is the only function changed
  int16 counter;
  fprintf(DEBUG,"LCD init\r");
  set_tris_lcd(0xff);//TRIS DATA bus,note:control bus always outputs
  LCD.w_bar=1;      // INITIAL STATES OF CONTROL PINS
  LCD.r_bar=1;      //
  LCD.ce_bar=0;     //
  LCD.cd=1;         // data
  LCD.fs=LCDFont;   // FontSelect
  LCD.reset_bar=0;  // preform a reset
  delay_us(2);      // delay the prescribed time for a reset
  LCD.reset_bar=1;  // run
  //Set up the graphics and text areas
  glcd_WriteCmd2(TextHome,0x40);
  glcd_WriteCmd2(AreaSet_T,0x41);
  glcd_WriteCmd2(GraphicsHome,0x42);
  glcd_WriteCmd2(AreaSet_G,0x43);
  //Clear all RAM of LCD
  glcd_WriteByte(1,AutoModeWrite);
  for (counter=0;counter<0xffff;++counter)
    glcd_WriteByteAuto(0);//fill everything with zeros
  glcd_WriteByte(1,AutoModeReset);
  fprintf(DEBUG,"LCD init DONE.\r");
// Purpose:       Writes a byte of data from the current location
// Inputs:        cd  1=command 0=data     BYTE data
// Ouputs:        Int1 1=success 0=failure
  BYTE status=0,count=0;
    set_tris_lcd(0xFF);
    LCD.w_bar=1;LCD.r_bar=1;LCD.cd=1;LCD.fs=LCDFont;//defaults
WriteByteLabel:
    // First section checks if LCD is busy
    LCD.r_bar=0;      // Read
    status=LCD.data;  // Latch data
    LCD.r_bar=1;      // Release
    ++count;
    if (count>LCDMaxBusyCount)
      fprintf(DEBUG,"-Error writing to LCD,.. Busy\r");
      return(0);
  if (!bit_test(status,0) || !bit_test(status,1)) //loop if either is 0
        goto WriteByteLabel;
  //if(cd==0) {fprintf(DEBUG,"Data=   %lx\r",data);}
  //if(cd==1) {fprintf(DEBUG,"Command %lx\r",data);}
    set_tris_lcd(0x00); //All outputs
    LCD.cd=cd;          //Command/Data bar
    LCD.data=data;
    LCD.r_bar=1;        //not read
    LCD.w_bar=0;        //write
    set_tris_lcd(0xFF); //Port D tristate ie: all inputs
    return (1);   //Return status
// Purpose:       Writes continuous bytes of data from the current location
// Inputs:        BYTE data
  BYTE status=0,count=0;    //status bits ARE DIFFERENT BITS THAN NORMAL
    set_tris_lcd(0xFF);   //First section checks if LCD is busy
    LCD.w_bar=1;LCD.r_bar=1;LCD.cd=1;LCD.fs=1;//defaults
  do
    ++count;
      fprintf(DEBUG,"0Error writing to LCD,.. Busy status=%x\r",status);
      return(0);
  }while (!bit_test(status,3));//Check until bit3==1 (ready)
  LCD.cd=0;           //This is always data, cd=0
  LCD.data=data;      //Put data on data bus
  LCD.w_bar=1;        //release
// Purpose:       Writes a one byte of data and a command
// Inputs:        BYTE data     BYTE cmd
  if (!glcd_WriteByte(0,data)){
    fprintf(DEBUG,"2Error LCD is Busy\r");
    return (0);
  if (!glcd_WriteByte(1,cmd)){
    fprintf(DEBUG,"3Error LCD is Busy\r");
    return (0);
  return (1);
// Purpose:       Writes a two data byte command
// Inputs:        int16 data     BYTE cmd
  if (!glcd_WriteByte(0,data & 0xFF)){
    fprintf(DEBUG,"1Error LCD is Busy\r");
    return (0);
  if (!glcd_WriteByte(0,data>>8)){
    fprintf(DEBUG,"2Error LCD is Busy\r");return (0);
    return (0);
  return (1);
// Purpose:       Reads a byte of data from the current location
// Ouputs:        A byte of data read from the LCD
  BYTE data,status,count=0;          // Stores the data read from the LCD
  set_tris_lcd(0xFF)  ;  //First section checks if LCD is busy
  LCD.cd=0;
ReadByteLabel:
  ++count;
    return(0);
    //        fprintf(DEBUG,".");
    goto ReadByteLabel;
  LCD.cd=0;          // Command/Data bar
  LCD.r_bar=0;        // read
  data=LCD.data;
  LCD.r_bar=1;
  return data;        //Return the read data
// Purpose:       Sends data to LCD
void glcd_putc( char c) {
  //fprintf(DEBUG,"->%x\r",c);
   switch (c) {
//     case '\f'   : lcd_send_byte(0,1);
//                   delay_ms(2);
//                                           break;
//     case '\n'   : lcd_gotoxy(1,2);        break;
//     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : glcd_WriteCmd1(c-0x20,0xc0);break;//Write to LCD autoinc
xmen
PostPosted: Fri Jul 30, 2004 9:23 pm     Reply with quote
Hello Treitmey:
In your source code, there are a lot of functions that are not in source code.
Concretely, are not:
May you provide full source code, please ?
Regards.
PostPosted: Sat Jul 31, 2004 12:40 pm     Reply with quote
Treitmey,
You can put it in the code library... For us thats the "file pile"
Laughing
