weired A3, A4, A5 for 12f675
young
PostPosted: Thu Jul 29, 2004 12:50 pm     Reply with quote
I used the following program to test input and output, A0-A2 works fine, but I could not see any activities on A3, A4, A5 port. I just used them to output low and high to led to see the result, no response for them. I tried pull up and down these three port, but nothing happened.
#if defined(__PCM__)
#include <12F675.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,NOMCLR
//#use rs232(baud=9600, parity=N, BITS=8, xmit=PIN_A5,RCV=PIN_A4)
#byte CMCON = 0x19
  int8 val1,val2;
  CMCON = 7; // Comparators off
   set_tris_a(0b00000101);
   setup_adc_ports(sAN0|sAN2);
   setup_adc( ADC_CLOCK_INTERNAL );
   while(1) {
   set_adc_channel( 2 );  //A2 as ADC
   delay_us(50);
   val2 = Read_ADC();
   set_adc_channel( 0 ); //A0 as ADC
   delay_us(50);
   val1=read_adc();
   if((val1>146) && (val2>146))
    output_High(PIN_A1);
   output_low(PIN_A1);
   if((val1>146) && (val2<146))
     output_high(PIN_A5);
     output_low(PIN_A5);
   if((val1<146) && (val2>146))
     output_high(PIN_A3);
     output_low(PIN_A3);
   if((val1<146) && (val2<146))
     output_high(PIN_A4);
     output_low(PIN_A4);
young
PostPosted: Thu Jul 29, 2004 12:55 pm     Reply with quote
I also could not used them as ADC port for input.
PostPosted: Thu Jul 29, 2004 2:37 pm     Reply with quote
First obvious comment. A3, is _only_ an input pin. It cannot function as an output on this chip....
Second thing is that if val2, never gets below 146, A4, and A5, will never operate. I'd suspect there is something wrong in the connections round this pin.
young
PostPosted: Thu Jul 29, 2004 2:41 pm     Reply with quote
As you pointed out A3 is always a input pin, I just found it out also from the data sheet. regarding the A4, A5, I tried val1 and val2 to control the A1 pin, it works fine.
Mark
PostPosted: Thu Jul 29, 2004 2:51 pm     Reply with quote
See your previous post and you will find someone already pointed that out.
http://www.ccsinfo.com/forum/viewtopic.php?t=20049
young
PostPosted: Thu Jul 29, 2004 3:03 pm     Reply with quote
I even tried this it still does not work, I already set comparators off, I can not use set_comparators(NC_NC_NC_NC); compiler said it does not being defined, however the 12f675.h has this functions.
#include <12F675.h>
#byte CMCON = 0x19
output_low(PIN_A4);
output_low(PIN_A5);
young
PostPosted: Thu Jul 29, 2004 3:13 pm     Reply with quote
typo: it is setup_comparators() not being defined more weired?
young
PostPosted: Thu Jul 29, 2004 3:48 pm     Reply with quote
Any specific directions? I tried this also
output_high(PIN_A0);
output_high(PIN_A1);
output_high(PIN_A2);
output_low(PIN_A0);
output_low(PIN_A1);
output_low(PIN_A2);
output_low(PIN_A4);
output_low(PIN_A5);
A0-A2 is working, A4,A5 does not?
PostPosted: Fri Jul 30, 2004 2:18 am     Reply with quote
output_low(PIN_A0);
output_low(PIN_A1);
output_low(PIN_A2);
output_low(PIN_A4);
output_low(PIN_A5);
Take the chip out, and verify that you can pull the signals high with a resistor.
How old is the compiler?. The _setup_comparator_ (note no 's') function works fine for me, and everything you show should work.
PostPosted: Fri Jul 30, 2004 5:52 am     Reply with quote
Thank you, you are right, I put 's' at the end of the function, I correct it. setup_comparator() now is working, but A4-A5 is still not working>
PostPosted: Fri Jul 30, 2004 6:21 am     Reply with quote
OK, I found out, the board I am using just connected A0-A2 pin with led, not the A4-A5 of 12f675, Stuip board weiring caused me one day to find out! I found out when I am using easy2 board, I have to face some challanges like these, not once, several times!!!
languer
PostPosted: Fri Jul 30, 2004 1:39 pm     Reply with quote
sure, blame the arrow Cool
