sAN0 and sAN2 adc conversion setup
young
PostPosted: Wed Jul 28, 2004 1:28 pm     Reply with quote
May I setup port A0, A1, A3 and ADC port in 16f675 as
setup_adc_ports(sAN0|sAN1|sAN2);
PostPosted: Wed Jul 28, 2004 1:51 pm     Reply with quote
Yes, that's the way it works, except that you specified A0, A1, and A3,
so you should use sAN3 as the last parameter, and not sAN2. Example:
setup_adc_ports(sAN0|sAN1|sAN3);
young
PostPosted: Wed Jul 28, 2004 2:02 pm     Reply with quote
Thank you PCM:
How about if I want to set A0, A1, A2 as ADC port, A3 as digital input A4, A5 as output?
Is it like
set_tris_a(0b00001111);  setup_adc_ports(sAN0|sAN1|sAN2);
first set a0-a2 as output then set it as adc input right?
SherpaDoug
PostPosted: Wed Jul 28, 2004 2:26 pm     Reply with quote
You can't always do all combinations. The place to look is the chip's data sheet. It will tell you what is possible.
