RS232 driver
edi
RS232 driver
PostPosted: Wed Jul 28, 2004 1:15 am     Reply with quote
I want to send & receive strings to a controller via RS232.
I'm using PIC 16F877A.
I have to send it a control string like ("AT") : printf("at\r\n");
The controller return every char as echo and add his response string like : "OK" or "OK 1234".
I'm looking for C code that can check the response (ignore the echo).
The receive must be complete string and interupt driven.
Thanks in advance.
Edi
carlosma
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Jul 28, 2004 4:53 am     Reply with quote
Hello
I make something similar. But when send a printf"AT... , I disable interrupt #int_RDA. Now I do not read the echo.
enable_interrupt when I need to read from RS232.
Carlos
arunb
PostPosted: Sat Jul 31, 2004 11:23 pm     Reply with quote
You have to decide how many characters you want to receive, or you must send a specific character like EOF, etc. which will signify that the data transmission has ended, check your controller and see if it sends this end of data transmission character.
The following code should give you an idea.
I have assumed total characters to be 5, and end of transmission character as EOF. (13 )
You must paste this code extract to your program.
Also after receiving the data you must check manually for the required string.
thank you
arun
char dt(5);
int n;
#int_RDA
rs232()
char c;
c=getc();
if (c!=13)
dt(n)=c;
n++;
if (n>5)
n=0;
// The buffer is full, clear the buffer and start again. Also execute rest of the code.
PostPosted: Sun Aug 01, 2004 1:55 am     Reply with quote
Thanks,
Edi
