free function hangs up PIC
joseosanchez
PostPosted: Mon Jul 26, 2004 3:09 pm     Reply with quote
Hi I implemented a linked list on my PIC which contains the sensors connected to the CAN bus, however, when I unplug a sensor and I try to remove the sensor from the list, sometimes it hangs up when it calls the free function. I debbuged the code using ICD and everythings seems to be ok until the free function is called where it stays forever.
My remove functios is as follows:
int removeSensor(int16 id)
struct sensors *curr=NULL, *prev=NULL;
if(selectsensor(id)==NOTFOUND)
return(NOTFOUND);
if(first->id==id)
curr=first;
first=curr->next;
prev=first;
curr=first->next;
while(!(curr->id==id))
prev=curr;
curr=curr->next;
prev->next=curr->next;
free(curr);
anz-=1;
return(OK);
I hope someone has an idea how to solve this problem.
thanks
Jose
Haplo
PostPosted: Mon Jul 26, 2004 5:08 pm     Reply with quote
The code for free() is in the STDLIBM.H file. Debug your code, and instead of jumping over the free() function step through it. This way you shuold be able to figure out what exactly is causing the problem.
joseosanchez
PostPosted: Tue Jul 27, 2004 8:31 am     Reply with quote
I was debbuging the code and I noticed that it hangs up in the function traverse() located in stdlibm.h and specially in a function that traverse calls which is remove_node located in memmgmt.c. For the moment being I removed the free function and the PIC does not hangs but of course I am leaving spaces of memory without allocation which is not right, but I have no idea what to do to solve this problem.
any ideas.
Jose
