moving from PIC16F876 to PIC18F252
runtime
PostPosted: Thu Jul 22, 2004 2:21 pm     Reply with quote
Thank you for all your replies to my UART post, on another topic, I'm moving from PIC16F876 to a PIC18F252, I upgraded to PCH, I will use a 10Mhz osc, can someone please tell me how do I have to have the FUSES configured? what else should I change to my F876 programms?
Thank you
Peter
valemike
Not much change at all...
PostPosted: Thu Jul 22, 2004 3:16 pm     Reply with quote
Not much changes at all. I have the following #fuse statement on my app...(it uses a 4MHz clock though).
#include <18F252.h>
Same statements work on the 18F876 (with the appropriate #include of course).
Someone correct me if i'm wrong, but I believe you don't even need to use the "#device *=16" statement (that uses 16 bit pointers) for the 18f452 if you used them in the 876. heck, you don't even need to use the #separate statement either. A lot of good comes out of using the 18F stuff.
runtime
PostPosted: Thu Jul 22, 2004 3:55 pm     Reply with quote
If I am going to use a 10MHz osc (ceramic osc with built in caps), should I configure the PLL 4 x clock to get it running at 40Mhz? what's best: to have it at plain 10Mhz or kick it to 40MHz?
Best Regards
Mark
PostPosted: Thu Jul 22, 2004 6:35 pm     Reply with quote
I think you might have to do something to Timer0 if memory serves me correctly. It is now 16 bit but can be configured for 8 bit.
rnielsen
PostPosted: Fri Jul 23, 2004 8:31 am     Reply with quote
If you have any registers defined you'll need to change the address of your defines. Check ALL of the timers to make sure you have them configured correctly. I haven't looked at the data sheet but make sure your I/O pins haven't moved around (like your serial or I2C pins). And check anything else I can't think of either. Rolling Eyes
Mark
PostPosted: Fri Jul 23, 2004 9:02 am     Reply with quote
Seems like I remember they changed the LVP pin from B5 to B3 or vice versa. If you don't specify the NOLVP fuse then your program might hang if there is a change on the LVP pin
