wrong communication data transfer
Goto page 1, 2, 3  Next
young
PostPosted: Wed Jul 21, 2004 12:41 pm     Reply with quote
I have used
int8 val1;
val1=235;
printf("%2u",val1);
to sent data to serial port com1, and using the miscrosoft communication control 6.0 to receive dat, however, the data I reveived was strange character, what might cause this problem?
PostPosted: Wed Jul 21, 2004 1:41 pm     Reply with quote
any hint?
SherpaDoug
PostPosted: Wed Jul 21, 2004 2:10 pm     Reply with quote
Could you at least tell us what the strange character was, preferably the binary value?
PostPosted: Wed Jul 21, 2004 2:27 pm     Reply with quote
Following is my RS232 testing file,
after download the file to the chip. I tried to monitor the result using serial port monitor under CCS PCW compiler, all data are zero, what is wrong with this program?
#if defined(__PCM__)
#include <16F877A.h>
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
//I connected RX to RC7, TX to RC6
   BYTE value;
   int val1;
   setup_port_a(ALL_ANALOG);
   setup_adc( ADC_CLOCK_INTERNAL );
   do {
     set_adc_channel( 1 );
     delay_us(50);
     val1 = Read_ADC();
     printf("%u\r\n",val1);
   } while (TRUE);
PostPosted: Wed Jul 21, 2004 2:43 pm     Reply with quote
I could not type the character, it looks like the 0b11100001 in windows screen. however all 0 when I use the serial monitor. in order to find out what is wrong step by step, I made the above program only ccs and same result, what is wrong with the ccs c program? maybe after I find out problem here, I could go another step to vc programming.
valemike
Check your hardware
PostPosted: Wed Jul 21, 2004 2:51 pm     Reply with quote
#include <18F448.h>
   BYTE value;
   int val1;
   do {
     delay_us(50);
     val1 = Read_ADC();
   } while (TRUE);
My output looked like:
112
112
112
112
112
112
112
111
112
111
111
112
No garbage characters when I printed it out. Check your hardware to make sure your connections are correct. I used Hyperterminal to print my chars out... (9600-8-N-1)
PostPosted: Wed Jul 21, 2004 2:53 pm     Reply with quote
after I changed the baud rate it is now showing F0 00 00 00 00 00 F0 00 00, I also changed printf("%u\r\n",val1) to printf("%u",val1)
PostPosted: Wed Jul 21, 2004 2:56 pm     Reply with quote
How are you connecting the serial?.
PostPosted: Wed Jul 21, 2004 3:02 pm     Reply with quote
When I use my original program, it is showing F0 00 00 F0 F0 F0 00 00 F0 00, F0 00 00 00 00 f0 00, 00 00 00 f0 00 00 00 00, 00 00 00 00 f0 00 f0 00 00.
PostPosted: Wed Jul 21, 2004 3:06 pm     Reply with quote
I connected com1 with RS232 port on my PICeasy2 board, and RX was connected with RC7, TX was connected with RC6?
PostPosted: Wed Jul 21, 2004 3:13 pm     Reply with quote
what you mean hyperterminal, I do not know the word yet. is it the serial monitor in PCW IDE
PostPosted: Wed Jul 21, 2004 3:22 pm     Reply with quote
Ok, I found hyperterminal.
PostPosted: Wed Jul 21, 2004 3:33 pm     Reply with quote
when I use hyperterminal, there is nothing happened?
young
PostPosted: Wed Jul 21, 2004 4:26 pm     Reply with quote
any further help?
Mark
PostPosted: Wed Jul 21, 2004 5:58 pm     Reply with quote
Are you using a RS232 transceiver chip like a Max232 between the PC serial port and the PIC?
Page 1 of 3
