Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
| H4 does it work? (PLL 4 x clock multiplier) |
Posted: Tue Jul 20, 2004 4:22 am |
I am having great difficulty in getting my 18F442 to run at 40MHz. For development I was using a 40Mhz crystal, no problem I though, for production I can use 10MHz and set the H4 fuse!
Wrong! PIC runs at 10MHz!
Any ideas what I am doing incorrect. My fuse statment is:
#fuses H4,NOWDT,NOPUT,DEBUG,NOLVP
I am about to dig myself into the datasheet to set the registeres manually, but is there a CCS way of doing it?
Will |
| Re: H4 does it work? (PLL 4 x clock multiplier) |
Posted: Tue Jul 20, 2004 4:35 am |
| Will Reeve wrote: | Hi,
Will |
I'm amazed you got the chip to run at 40MHz, using a 40MHz 'crystal', since the internal oscillator is only rated for 25MHz max, and though it will sometimes go a little beyond this, usually fails well short of 40Mhz. The fact that you got it to run, implies that your 40MHz crystal, may have a very high gain. Now if the one being used for H4 operation, is from the same 'family', and has similar characteristics, it probably explains your problem. The PLL, will fail to work, if the input is overdriven. Hence with high gain crystals, it becoms neessary to add a resistor, as an attenuator to bring the signal level down. The question also arises of how old the chip is, since early versions of this family, definately had this problem 'worse', than the current releases.
H4, does work (though check the 'fuses' in your programmer, and verify that what is being written to the chip, is the same as you have selected), but it is a somewhat more 'fussy' configuration than the normal PIC oscillator.
Best Wishs |
lucky
Joined: 12 Sep 2003 Posts: 46 Location: South Coast - England
| H4 |
Posted: Tue Jul 20, 2004 4:36 am |
Hi Will,
Are you setting the #use delay correctly?
#fuses H4, NOWDT, PUT, BROWNOUT, WRT, NOOSCSEN, BROWNOUT, BORV27, STVREN, NOLVP, NODEBUG
#use delay(clock=40000000,RESTART_WDT)
Works for me to give 40MHz from a 10MHz clock on my MP3 player. _________________ Lucky
www.mpic3.com - MPIC3 player project, Forum, Downloads, Online Shop |
Will Reeve
Posted: Tue Jul 20, 2004 5:53 am |
Hi guys,
I was using a 4pin 40MHz crystal in the old Microchip development board. The new design uses a 10MHz ceramic oscillator with built in decoupling caps (it's three pins one of which is GND). I've scoped the osc pins and there is a lovely 10MHz sine wave present on the osc2 pin.
Here is the end of my list file:
Configuration Fuses:
Word 1: 2600 H4 NOOSCSEN
So it would appear that the compiler is getting the first configuration word correct although I can't see where it actually lists the "programming" of it in the list file!
To answer your questions, both chips were "new" from Farnell in the UK, one was a 40pin PDIP (development) the other a 44pin PLCC (production).
I’ve now placed a 100Ohm resistor in the OSC2 line and low and behold the PLL appears to have kicked in and she is running at 40MHz!
Scoping the OSC2 pin and the sine wave looks just like before!
I’ve looked at the resonators datasheet (CSTCC) and nothing is mentioned about series resistors, is 100Ohm a sensible value?
You imply you shouldn’t run with an external clk frequency of 40MHz? I thought the 18F422 can run DC to 40MHz external freq?
Thanks for your help guys.
Will |
Posted: Tue Jul 20, 2004 6:34 am |
| Will Reeve wrote: | Hi guys,
Will |
There is a seperate 'application note', about oscillator use on the processors. This mentions the possible need for series resistors. The problem appears to be that the PLL, 'clips' internally, at a level slightly below the normal input. Hence it is more sensitive to this overdrive than the input itself...
The chip is specified to 'run' to 40MHz, using either H4, or an external oscillator. However the maximum frequency specified for the internal oscillator, is 25Mhz. This is 'Fosc', in table 22.4 of the data sheet.
If you are using an external osciallator, it is fine, but you said a 'crystal'. Being 'new', does not give any idea of the actual age of the chip. Look at the date code on the chip. This is also vital information for which silicon revision the chips are, and which 'errata' sheets apply...
Will Reeve
Posted: Tue Jul 20, 2004 7:39 am |
You are correct. My mistake. I was using an external crystal and over driving the internal osc circuit! Seemed to work OK.
On first inspection of the datasheet I read (or wanted to read!) 40MHz was ok as a Crystal, but that’s OK only as an external clock source!
I am amazed it worked, but it did!
Thanks for educating me. I learn something every time I read the forum!
Will |
Posted: Wed Jul 21, 2004 2:40 am |
| Will Reeve wrote: | You are correct. My mistake. I was using an external crystal and over driving the internal osc circuit! Seemed to work OK.
Will |
I think this well illustrates how much more 'annoying', the MicroChip data sheets have become, than their 'ancestors'. If you look at sheets for the early chips, they have features like tables showing the frequency for each oscillator option (and things like having the register addresses next to the names in the section of the sheet about particular registers). The current sheets have gone 'disparate', with the necessity to refer to the section on a particular feature, then look up the addresses or timings, in another part, without a clear cross reference....
It is a sad development, and one that has caught everyone dealing with the PIC processors at some time or another.
Glad it is working now.
Yes, 100R, os a reasonable value (usually perhaps 56R is a 'minimum', and 200R+, represents the point where the oscillator stops).
