Always false warning
Scotty
PostPosted: Mon Jul 19, 2004 8:47 am     Reply with quote
PCWH 3.206
I have something curious happening in my program and was wondering if anyone can explain it.
In line 17 below " if (!aff_power) init_done=0;" gives me a warning that it will always be false but the line works as it should.
I was wondering if anyone knows why i am getting the warning?
#define  AFF_Power   PIN_A1  //pin 18 - pin RA1
int init_done;
<snip>
        restart_wdt();
        // read the switch state to get start signal status
        start_signal = input(pin_A0);  // get start signal input
        if (input(MP_BOL)==unblocked){
            Jam_flag=0;
            jam_timer=0;
        if (!aff_power)
                        init_done=0;
 // Is the MP BOL blocked?
        if ((input(MP_BOL)== blocked) && (idle == 0))
            if (jam_flag==0) // is this the first time seen?
                jam_stop=0;
                jam_flag = 1;  // if so, start timer and set flag
                Jam_Timer = JAM_TIME;
rwyoung
PostPosted: Mon Jul 19, 2004 8:53 am     Reply with quote
I'm supprised it works at all.
The PIN_Ax assignments (as I understand them) are not the port addresses themselves. You are doing the same basic operation as
if (!22) init_done=0;
(substitue the value of PIN_A0 from your header file for 22).
You should either use the input_pin() function or use the #byte and #bit feature to map your pin to a variable.
FYI, if you use the input_pin() function then #use standard_io() will work as well as #use fast_io() and #use fixed_io()
However if you use the #byte and #bit you must set the pin direction by programming the appropriate TRIS register.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
