Sanity check on use of setup_oscillator()
object01
PostPosted: Fri Jul 16, 2004 1:35 pm     Reply with quote
I'm running on a PIC18F2320 @ 8MHz. I've got a state in my program that waits for a specified number of seconds. I'd like this delay to use as little power as possible without resorting to timer interrupts, and a colleague suggested that I set the internal oscillator to 31KHz from 8MHz. I tried the following, but it seemed to render the PIC kaput. I added the #use delay based on the information in PCW's readme.txt.
delay_seconds() uses delay_ms(), which I'm guessing is affected by the #use delay statement.
case Delay:
   trace ("Delay");
   setup_oscillator(OSC_31KHZ);
   #use delay (clock=31000)
   delay_seconds(60);
   setup_oscillator(OSC_8MHZ);
   #use delay (clock=8000000)
   state = Init_Program;
Jeff S.
PostPosted: Fri Jul 16, 2004 5:58 pm     Reply with quote
I didn't try to solve your problem by compiling your code
and looking at the .LST file.
But I can give you a tip that may pertain to your problem.
The "#use delay" statement is a linear statement. It does not
"follow" code as it goes from one function call to the next.
It just applies to any code that comes after it, until such time
as another #use delay statement is encountered.
So, your delay_seconds() function is very likely being
compiled based on a 8 MHz clock, but you're assuming it
will work with a 31.250 KHz clock as well.
If you want a delay routine that works with the slower clock,
I suggest that you put a "#use delay(31250)" statement
at the end of your program, and put in a new delay_seconds()
function with a special name at that point. Example:
#use delay(clock=31250)
void delay_seconds_31KHz(char seconds)
char i;
for(i = 0; i < seconds; i++)
Then change your main program code to call that function
instead of the normal delay_seconds() function. See the
line in bold, below.
case Delay:
trace ("Delay");
delay_seconds_31KHz(60); // Change this line
Also, I assume that the real clock speed is 31.250 KHz, so
you might want to change the #use delay statement to
reflect that.
I don't guarantee this will fix all your problems. There may
be a problem with switching oscillator frequencies, as well.
You should check the .LST file to verify that the code which
sets the frequency is correct. But at least my suggestion
should get you farther along.
