Timer2 causing Resets
ceegb2
PostPosted: Thu Jul 15, 2004 7:40 am     Reply with quote
I've got a problem with timer 2 on PIC18F8720, 20Mhz Clk.
I only use it for PWM outputs.
I set it up as:
setup_timer_2(T2_DIV_BY_1,0x65,1);
and when it gets called on an interrrupt :
#INT_TIMER2
void time_increment(void)
//do nothing
So nothing should happen when it gets called, just use dfor PWM o/p.
However, randomly when I get data in on the USART it causes the PIC to Reset. It is completly random, may be after the 2nd command comes in or after the 200th. All I know is when I comment out all code to do with timer 2 the PIC is fine.
I'm currently on CCSV3.129.
Any ideas or anyone had a similiar problem?
Graham Bremner
CS V3.129
Re: Timer2 causing Resets
PostPosted: Thu Jul 15, 2004 8:32 am     Reply with quote
ceegb2 wrote:
I set it up as:
#INT_TIMER2
//do nothing
Graham Bremner
CS V3.129
I'd suspect you are just trying to push too fast. You are programming an interrupt every 65 instruction cycles. The overhead to call and return from an interrupt handler, on the larger 18x chips, is typically 70 or more instructions....
SherpaDoug
PostPosted: Thu Jul 15, 2004 9:55 am     Reply with quote
Could your serial interrupt (assuming you are using a hardware UART) be interfering with your PWM interrupts causing you duty cycle to stay ON too long and causing power supply problems, leading to a RESET?
drh
PostPosted: Thu Jul 15, 2004 3:38 pm     Reply with quote
If you are using timer2 ONLY with the PWM module, you don't need to enable the timer 2 interrupt or service that interrupt.
