what caused programming, ID, eeprom error
Goto page 1, 2  Next
young
PostPosted: Thu Jul 15, 2004 7:40 am     Reply with quote
I used 16f877a chip before, and right now I am using 12f675 on my Picflash programmer, I wrote a program adopted from Moritz http://www.ccsinfo.com/forum/viewtopic.php?t=19801&highlight=12f675
#include <12F675.h>
#device ADC=10
#fuses INTRC_IO,NOWDT,NOBROWNOUT,NOPROTECT,PUT,MCLR
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
#byte CMCON = 0x19
int16 Value=300;
ADCON0 = 0; // ADC off
ANSEL = 0; // GPIO pins 0,1,2 and 4 set to all digital
CMCON = 7; // Comparators off
//set_tris_a(0b00000111);//RA0, RA1, RA2 as Inputs RA3, RA4, RA5 as Outputs
setup_adc_ports( AN0_ANALOG );
setup_adc(ADC_CLOCK_INTERNAL );
set_adc_channel(0);
delay_ms(150);                     // Allow the channel to be aquired
output_high(pin_a5);
delay_ms (250);
output_low(pin_a5);
delay_ms(10);
Value=read_adc();
delay_ms(10);
   if (Value > 512)//If more than 50% Flash fast
      output_high(pin_a4);
      delay_ms (250);
      output_low(pin_a4);
      delay_ms(250);
   else //if (Value < 513) Flash slow
      delay_ms (1500);
      output_low(pin_a4);
      delay_ms(1500);
I compiled successfully in ccs, but when I download the hex file to 12f675, program failed error occured, the following is the error msg.
program:1021 errors
eeprom: 128 errors
IDs: 4 errors
what happened, is there any configuration I need to setup?
PostPosted: Thu Jul 15, 2004 8:19 am     Reply with quote
when I configured all IDs as 0000, ID errors dispeared. how about others?
PostPosted: Thu Jul 15, 2004 8:24 am     Reply with quote
On the left bottom side of the PIC flash, there is a option configuration button, when I not check these items, certainly the program will pass, but the program is not work, nothing shown on my led, so, there should be some other problem, and I thnk I should check all these items, but how to solve the problem!
PostPosted: Thu Jul 15, 2004 8:29 am     Reply with quote
I even modified jusy as simple as
//Value=read_adc();
//delay_ms(10);
//   if (Value > 512)//If more than 50% Flash fast
      output_high(pin_a1);
      delay_ms (250);
      output_low(pin_a1);
      delay_ms(250);
it is still not working!!
any suggestions?
PostPosted: Thu Jul 15, 2004 9:13 am     Reply with quote
when I download the hex file to my 16f877a, there is no error, and program is running well! help me please, what is the problem with 12f675? what is all these error about?
jds-pic
PostPosted: Thu Jul 15, 2004 9:34 am     Reply with quote
once again, a reminder to READ THE DATABOOK.
the 16f877a and 12f675 are not the same architecture,
and can not use the same hex file.
jds-pic
PostPosted: Thu Jul 15, 2004 10:02 am     Reply with quote
Thank you:
I am not using the same hex file, when I program the 12f675, I changed setting and compiled them acordingly. can you tell me exactly which part might affect it, or more directly, which part should I pay more attention to read on the datasheet?
PostPosted: Thu Jul 15, 2004 2:26 pm     Reply with quote
Is 12f675 a 12 bit or 14 bit chip?
jds-pic
PostPosted: Thu Jul 15, 2004 2:31 pm     Reply with quote
<and then>
i think you answered your own question.
jds-pic
PostPosted: Thu Jul 15, 2004 2:39 pm     Reply with quote
I thought it is 12 bits, but some guys in this group said it is 14bits? I got confused. It is 12 bits right?
PostPosted: Thu Jul 15, 2004 2:52 pm     Reply with quote
It is an 'oddity'. Normally, the '12' chips use a 12bit core, however there ae a couple of chips (the 12F675, and 629), which use 14bit code, despite having a '12' number. hence they use the 'PCM' compiler.
Why Microchip elected to put it into their '12' range, is strange, given this difference...
PostPosted: Thu Jul 15, 2004 2:58 pm     Reply with quote
Thank you:
So what is OSSCAL, and how to set up them, also the ID locations.
young
PostPosted: Fri Jul 16, 2004 7:39 am     Reply with quote
are there anyone can help me out of these error problem? I kind of got frustrate about it, but Still looking for start light shining somewhere?
[code]
#if defined(__PCM__)
#include <12F675.h>
#device ADC=10
#fuses INTRC_IO,NOWDT,NOPROTECT
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
#byte CMCON = 0x19
#use delay(clock=20000000)
int16 Value=300;
setup_adc_ports(AN0_ANALOG );
set_adc_channel(0);
delay_ms (250);
output_low(pin_a5);
delay_ms(10);
int32 i;
Value=read_adc();
delay_ms(10);
delay_ms(250);
output_low(pin_a1);
delay_ms(250);
delay_ms (1500);
output_low(pin_a4);
delay_ms(1500);
[\code]
Thank you?
young
PostPosted: Fri Jul 16, 2004 8:14 am     Reply with quote
anyone use the PICflash to write hex to PICeasy2 board? I have no problem with the 16f877a big board, but have these errors write to 12f675 small board, are there any setting change required? I connected the board using usb port.
PostPosted: Fri Jul 16, 2004 10:30 am     Reply with quote
[img]
This is the error image, would any one help me please
Please!
[/img]
[/url]
Goto page 1, 2  Next
Page 1 of 2
