ICD-U40 not working with another board using an FTDI
treitmey
PostPosted: Wed Jul 14, 2004 1:16 pm     Reply with quote
Has anyone had problems with the ICD-U40 working while another board using an FTDI chip is also running?
I am using an B&B electronics USB-RS485 converter, .. model USOTL4.
Inside it uses the FTDI FT232AM chip and I use the latest direct drivers.
After I start the above board I try to also program with the ICD-U40
It fails with an invaid USB handle.
Are the drivers stepping on each other?
The ICD-U40 is using the FTDI FT232BM chip.
During install I install the ICD-U40 then the USOTL4.
I've also uninstall both and reversed the install order, but without help.
Latter on I switched the USOTL4 to VID_0856&PID_AC01
That is what came from the manufaturer.
I was given a block of PIDs from FTDI. xxxx to xxxx
so a VID_0403&PID_xxxx should be valid.
It seems that CCS must check the VID and then use that handle.
THAT SEEMS BAD. VERY BAD.
You are not the only kid on the block using FTDI's chip and a FTDI generated id (ie: ICD-U40 has a VID_0403&PID_F9D0)
The vender ID of 0403(FTDI) is used by many people and many boards.
CCS.
Instead of using the VID, try using the name of the device,... or something else like VID&PID
Haplo
PostPosted: Wed Jul 14, 2004 5:58 pm     Reply with quote
A quick question, what ooperating system are you using?
Windows 98 has serious problems with having two of the same USB 'devices' connected to the PC at the same time.
treitmey
PostPosted: Thu Jul 15, 2004 8:31 am     Reply with quote
Nope, not the case. I have windows XP pro.
Darren Rook
PostPosted: Thu Jul 15, 2004 9:27 am     Reply with quote
CCS does check the PID.
planix
PostPosted: Sun Mar 18, 2007 4:10 am     Reply with quote
i have the same problem as you mentioned.
i have another usb programmer using ftdi232 after installing icd-u40 drivers it fails programming. this is verified by removing ucd drivers and installling original ftdi drivers.
i don't know if ccs c checks for pid or what but this can cause really big problems as we think lots of boards using fdti chips.
Neutone
Re: ICD-U40 not working with another board using an FTDI
PostPosted: Tue Mar 20, 2007 1:39 pm     Reply with quote
I have had a problem. The drivers supplied by CCS are older than the ones supplied by B&B. For some reason the ICD-U40 will not work with the newer drivers. The USOTL4 will work with the older drivers that CCS supply. To get this working you have to force the USOTL4 to uses the drivers already installed by CCS.
I don't think problem this has anything to do with VID or PID.
I don't know how CCS implemented the FTDI chip but simply upgrading to a newer version of FTDI drivers breaks the ICD. I don't know if this problem is due to FTDI , CCS or both but it should be fixed. The impression it gives is bad. Maybe CCS can switch to the newer driver version as a way to fix this.
Saraoga_
ftdi
PostPosted: Fri May 11, 2007 6:06 am     Reply with quote
Donwload Mprog from this page;
www_ftdichip._com/Resources/Utilities.htm
And clone FT232bm config via usb.
Martin Berriman
PostPosted: Fri May 25, 2007 7:59 am     Reply with quote
It is true, CCS does not play nicely when other FTDI devices are plugges in - it is pretty poor really - I have been putting up with it for over a year now and just checked on here today to see if there were any recent thoughts.
I have designed a couple of products using FTDI devices and had trouble getting the CCS debugger to work - I have to fudge it by starting the debugger with my board unplugged then once CCS says Attaching, I plug my board in and normally everything is ok - If I don't follow that procedure then I get the error - 'Access violation in ftd2xx.dll'.
It definitely seems like that. I was concerned about that with my products so I actually rename the FTDI drivers so that I can be sure they do not get overridden with older versions. When I open my FTDI devices, I use the FT_OpenEX and specify OpenByDescription whereas CCS seem to get confused if there is any other FTDI device attached.
Well CCS definitely does something nasty - see the crash message above.
I've been hoping they would fix this for a long time but seeing as this thread was started in 2004 I will not hold my breath. Rolling Eyes
Edit:
Treitmey has a neat solution to workaround the CCS problems - see this post.
