prob with trisc
Andre Jr. Richard
prob with trisc
PostPosted: Thu Jul 08, 2004 8:39 am     Reply with quote
I try to access to pin c2 without manage the trisc.
I'm able to access all the other ports pins in that condition with using:
#bit RB0 = PORTB.0 for example.
In my program I can do:
RB0 = 1; or if(RB0){}
and that code work perfectly i.e the trisb is manage by compiler.
Why i'm unable to do the same with the portc pin ? i.e the trisc isn't manage by compiler ?
I don't use: #use fast_io(c) and I'm unable to do this command anyway with portc only, why ?
is it normal ? and why ?
thanks
PostPosted: Thu Jul 08, 2004 9:44 am     Reply with quote
The compiler does not manage the TRISB when you write directly
to port pins. Here is a sample program:
#include <16F877.H>
#use delay(clock = 4000000)
#byte PORTB = 6
#bit RB0 = PORTB.0
RB0 = 1;
Here is the .LST file for the above program. Notice that
there is no ASM code that writes to the TRISB register.
So this program will not work. That's because the i/o
ports are configured as input pins upon power-up.
0000                00273 .................... void main()
0000                00274 .................... {
0004 0184       00275 CLRF   04
0005 301F       00276 MOVLW  1F
0006 0583       00277 ANDWF  03,F
0007 3006       00278 MOVLW  06
0008 1683       00279 BSF    03.5
0009 009F       00280 MOVWF  1F
0000                00281 ....................
0000                00282 .................... RB0 = 1;
000A 1283       00283 BCF    03.5
000B 1406       00284 BSF    06.0
0000                00285 ....................
0000                00286 ....................
0000                00287 .................... while(1);
000C 280C       00288 GOTO   00C
If you want to write directly to port pins which are declared
with #bit statements, then you need to set the TRIS first.
Example:
set_tris_b(0xFE); // Set pin RB0 to be an output pin
Here is the ASM code for the revised program.
Notice how the TRISB register is now set.
0000                00282 .................... set_tris_b(0xFE);
000A 30FE       00283 MOVLW  FE
000B 0086       00284 MOVWF  06
0000                00285 .................... RB0 = 1;
000C 1283       00286 BCF    03.5
000D 1406       00287 BSF    06.0
0000                00288 ....................
0000                00289 ....................
0000                00290 .................... while(1);
000E 280E       00291 GOTO   00E
If you want to let the compiler manage the TRIS for you,
then you need to use "standard i/o" mode (which is the
default mode), and you need to use these CCS functions:
output_low();
output_high();
output_bit();
input();
etc.
To discover what the compiler is doing, you need to compile
a small test program and look at the .LST file.
Re: prob with trisc
PostPosted: Thu Jul 08, 2004 9:51 am     Reply with quote
thanks
The 'key' (as has been pointed out by anothr poster), is that when you direct IO like this, _the compiler does not 'manage' the TRIS_. The reason it is working with the other registers, is that you have done other operations allready on the port, that have left the TRIS register set to the required mode. If you want the compiler to handle TRIS, then use the 'output_bit' instruction (or output_high/output_low), for which the compiler will set the TRIS register.
Andre Jr. Richard
PostPosted: Fri Jul 09, 2004 8:24 am     Reply with quote
The tris wasn't ok... but physicly the hardware makes that work anyway....
I programed like that since 2 month without problem... Evil or Very Mad
I see in my list file you said right Shocked
I will program far the edge Wink
Thanks for your reply.
