PIC18F8920... RTCC as 16 bit timer
Pogostik
PostPosted: Tue Jul 06, 2004 9:17 am     Reply with quote
I have been trying to use Timer0 in an 18F8720 device as a 16-bit timer. I can get my code to work when it is configured as an 8-bit counter, but when I set it to 16-bits, no interrupts occur. Here is a code snippet of a modified version of EX_STWT.C example from CCS:
#int_timer0 // This function is called every time
void clock_isr() { // the RTCC (timer0) overflows (255->0).
// For this program this is apx 76 times
if(--int_count==0) { // per second.
++seconds;
int_count = INTS_PER_SECOND;
void main (void)
BYTE start;
set_timer0 (0);
setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_BIT);
InitializeSystem();
do {
printf("Press any key to begin.\n\r");
getc();
start=seconds;
printf("Press any key to stop.\n\r");
getc();
printf("%u seconds.\n\r",seconds-start);
} while (TRUE);
When the initialization line is as follows timer 0 interrupts are generated.
When the RTCC_8_BIT option is eliminated, which should cause timer 0 to become 16-bit, timer0 interrupts do not occur.
setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_256);
Anyone experienced this? Is there a work-around? Thanks.
Pogostik
Typo in headline... Pls excuse
PostPosted: Tue Jul 06, 2004 9:20 am     Reply with quote
In my header I meant to type 18F8720. I don't think the 18F8920 is available yet....
PostPosted: Tue Jul 06, 2004 10:13 am     Reply with quote
Did you wait enough time? Setting up timer0 to 16 bit in your case could means 256 seconds (cca. 4 minutes) instead of the original 1 second.
Pogostik
PostPosted: Tue Jul 06, 2004 10:27 am     Reply with quote
Are you saying... setting timer0 to 16 bits and initializing it to 0 would result in 65535 ticks before interrupt; whereas setting it to 8 bits would require only 256 ticks before interrupt? I think that may be it. Let me try it with those adjustments.
OK... it works fine now. Thanks for the tip...
