waseem
| Printf & floating numbers |
Posted: Mon Jul 05, 2004 2:12 am |
Hi!
Whenever i try to send a floating point number to an lcd usin printf function then someting strange happens.e.g if i send 2.30 then the number that is actually displayed is 2.29, similarly if i send 2.00 then the number 1.99 is displayed. What might be causing this?
 _________________ "Planet Earth, a place for peacelovers" |
Paolino
Posted: Mon Jul 05, 2004 2:41 am |
Which compiler version are you using? Which PIC? Can you post a little bit of code, please?
Paolo. |
| Re: Printf & floating numbers |
Posted: Mon Jul 05, 2004 3:36 am |
| waseem wrote: | Hi!
nothing wrong but simple truncation
there are no such thing as 2.3000000 in PIC, what stored in PIC memory is actuall something like 2.299999, because CCS float only use 32 bit, the accuracy is around 1.2e-7, try this then you will see some more digits
float x = 2.3;
printf("%f", x) |
