wrong temperature reading
Goto page Previous  1, 2
PostPosted: Thu Jul 08, 2004 9:19 am     Reply with quote
#include <16F877A.h>
#use delay(clock=2000000)
#fuses HS, NOWDT, NOPROTECT, NOPUT, NOBROWNOUT, NOLVP
I see a problem in the code above. The #use delay() statement
is set for only 2 MHz. But you're using the HS fuse, so I suspect
that you really using a 20 MHz crystal.
The effect of this mistake would be for all delay_ms() and delay_us()
statements to run 10x faster than expected. ie., delay_us(420);
would only delay for 42 us. This could cause everything to fail.
The statement should be changed to this:
#use delay(clock=20000000)
PostPosted: Thu Jul 08, 2004 9:40 am     Reply with quote
Thank uou PCM:
I do changed to 20mHz, but the reading is still same as before. 10 degree c
Kenny
PostPosted: Thu Jul 08, 2004 5:51 pm     Reply with quote
 if (temperatureMSB & 0b11111000) // if temp is negative rtn 0
      return(0);
   else {                           // else rtn the positive temp
      temperatureLSB=((temperatureLSB & 0b11110000)>>4);
      temperatureMSB=((temperatureMSB & 0b00000111)<<4);
   return(temperatureMSB | temperatureLSB);  // OR msb&lsb
The problem is probably that you have not modified the part of jds-pic's code above to suit the DS1820/DS18S20. This part has a fixed 9 bit resolution with 0.5 deg. C per bit compared to the DS1822/DS18B20 which has 12 bit resolution and 1/16 deg C per bit. The other difference is the one jds-pic mentioned ie the latter ones can have the resolution changed by setting the config reg bits. In other respects the code is the same.
Bytes 6 and 7 in the scratchpad can be used to improve resolution (see data sheet).
With the DS1820 the twos complement data is contained completely in the LSB and the MSB contains the sign bits (see data sheet), so the code needs to be changed to something like the following (if not using signed arithmetic):
if (temperatureMSB > 0) // if temp is negative rtn 0
return(0);
temperatureLSB=(temperatureLSB + 1)/2; // 0.5 deg C/bit, apply rounding by adding half denom.
return(temperatureLSB);
PostPosted: Thu Jul 08, 2004 10:39 pm     Reply with quote
You're having so much trouble making this work.
Peter Anderson has some code for the DS1820 on his website.
He uses the CCS compiler:
http://www.phanderson.com/PIC/PICC/CCS_PCM/ds1820.html
Here's the main page:
http://www.phanderson.com/PIC/PICC/index.html
The only problem with his code is that he doesn't always
use CCS functions. For example, he writes his own
delay functions, in order to make his code be more
"universal". But by doing so, he makes it more
difficult for CCS users who run their PIC at a different
crystal frequency than he uses. So I suggest that
when you see his code like this
delay_10us(50);
then you should change it to use the CCS function, like this:
delay_us(500);  // 10 us x 50 = 500 us
Also, delete his delay_ms() function, since CCS has its own
delay_ms() function.
At the end of his DS1820 code, he has some LCD code which
you don't need. Just delete it.
PostPosted: Fri Jul 09, 2004 6:29 am     Reply with quote
Hi PCM:
thank you for you answer.
I did make 1820 working using Peter Anderson's program after make a little modification on parasite power situation, when I change the connection to non-parasite power situation, the reading is consistantly 85 degree c. could you tell me why. and where should I changed. I tried to remove _1w_strong_pull_up(sensor); in the program, but there is no change.
#if defined(__PCM__)
#include <16F877a.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#include <lcd420_1.c>
#include <math.h>
#byte PORTA  =0x05
#byte TRISA  =0x85
#define MAX_SENSORS 4
// 1-wire prototypes
void _1w_init(int sensor);
int _1w_in_byte(int sensor);
void _1w_out_byte(int d, int sensor);
void _1w_pin_hi(int sensor);
void _1w_pin_low(int sensor);
void _1w_strong_pull_up(int sensor);   // not used in this routine
   int sensor, n;
   float buff;
   sensor=5;
 //  for (sensor=0; sensor<MAX_SENSORS; sensor++)
      _1w_init(sensor);
      _1w_out_byte(0xcc, sensor);  // skip ROM
      _1w_out_byte(0x44, sensor);  // perform temperature conversion
      _1w_init(sensor);
      _1w_out_byte(0xbe, sensor);  // read the result
      buff=(float)(_1w_in_byte(sensor))/(2.0);
      printf(lcd_putc,"               ");
      lcd_gotoxy(1,1);
      printf(lcd_putc,"* Temperature *");
      lcd_gotoxy(1,2);
      printf(lcd_putc,"Tem=%4.2f%1cC",buff,0xdf);
// The following are standard 1-Wire routines.
   _1w_pin_hi(sensor);
   _1w_pin_low(sensor);
   delay_us(50);
   _1w_pin_hi(sensor);
   delay_us(50);
   int n, i_byte, temp, mask;
   mask = 0xff & (~(0x01<<sensor));
   for (n=0; n<8; n++)
      PORTA=0x00;
      TRISA=mask;
      TRISA=0xff;
#asm
      CLRWDT
      NOP
      NOP
#endasm
      temp=PORTA;
      if (temp & ~mask)
        i_byte=(i_byte>>1) | 0x80;   // least sig bit first
        i_byte=i_byte >> 1;
      delay_us(6);
   return(i_byte);
   int n, mask;
   for(n=0; n<8; n++)
      if (d&0x01)
         PORTA=0;
         TRISA=mask;      // momentary low
         TRISA=0xff;
         delay_us(6);
          PORTA=0;
          TRISA=mask;
          delay_us(6);
          TRISA=0xff;
      d=d>>1;
   TRISA = 0xff;
   PORTA = 0x00;
   TRISA = 0xff & (~(0x01 << sensor));
void _1w_strong_pull_up(int sensor)   // bring DQ to strong +5VDC
   PORTA = 0x01 << sensor;
   delay_ms(120);
   TRISA = 0xff;
Jerry I
PostPosted: Fri Jul 09, 2004 4:14 pm     Reply with quote
Do you have more than one sensor.
This happened to me also, and I found out that sensor was dead.
Try that first.
Jerry Very Happy
PostPosted: Mon Jul 12, 2004 12:27 pm     Reply with quote
Hi Jerrt:
No I just have one 1820 sensor. I believe my sensor is working.
Page 2 of 2
