How to display special character degree c on LCD
young
PostPosted: Thu Jul 01, 2004 8:03 am     Reply with quote
I want to show temperature in degree c in my LCD, how to print out this special character degree C simble?
rwyoung
PostPosted: Thu Jul 01, 2004 8:09 am     Reply with quote
Find the data sheet for your LCD display. Most manufacturers include a table of displayable symbols. Use the table to figure out the code to send.
If the table does not have the degree symbol, then you can make your own and store it in the CGRam of the display and call that instead.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
young
PostPosted: Thu Jul 01, 2004 8:28 am     Reply with quote
I checked theback of my lcd it is CMC216NO6, I think it is from CMC company, however I could not find related datasheet anywhere, any suggestion that where I could get it?
Here's the data sheet
PostPosted: Thu Jul 01, 2004 8:39 am     Reply with quote
First hit on google brought up the (probable) data sheet for this....
Like most, 0xdf is the degree symbol.....
http://www.spezial.de/doc/cctech/cmc216-01.pdf
dyeatman
CMC216
This looks to be it... You will have to check and see.
Used Google and searched for CMC216 to find it.
young
PostPosted: Thu Jul 01, 2004 8:49 am     Reply with quote
Thank you, I got it.
young
PostPosted: Thu Jul 01, 2004 9:02 am     Reply with quote
Then after I know the code for degree c, then how should I program it
printf(lcd_putc, "%2d %sc",temperature, 0xdf);? oxdf is the code for degree c.
young
PostPosted: Thu Jul 01, 2004 9:04 am     Reply with quote
All right, I got it, It is printf(lcd_putc,"%2d %c",temperature, 0xdf);
Thank you again
SimpleAsPossible
PostPosted: Thu Jul 08, 2004 7:43 pm     Reply with quote
How about the escape sequence:
printf(lcd_putc, "%2d " "\xdf" "C", temperature);
or in octal notation which doesn't require the funny string stuff:
printf(lcd_putc, "%2d /337C",temperature, 0xdf);
PostPosted: Fri Jul 09, 2004 7:43 am     Reply with quote
is working fine
however the second command
have "printf type is invalide" error
