UART on PIC16F688
Goto page Previous  1, 2
guest
writing own putc()
PostPosted: Thu Sep 02, 2004 10:51 am     Reply with quote
I have found the same problem with the 16F688, I was able to transmit data using TXREG but not the standard putc() CCS includes by using #use rs232. why is that? do you know?
You will also need to create your own putc() and getc() functions.
I will show you how to make the putc() function:
#byte PIR1 = 0x0c
#bit TXIF = PIR1.1
#byte TXREG = 0x15
void my_putc(char c)
while(~TXIF);
TXREG = c;
}[/quote]
Page 2 of 2
