How to handle multiplication overflows?
Goto page Previous  1, 2
future
PostPosted: Fri Jun 25, 2004 11:03 am     Reply with quote
I will try the code tonight.
Looking at the faster way...
#else // faster way
   quot2 = val.w[1];
   val2.d = quot2 * 4295;
   // 16 bit answer is val.w[1]
Should the 16 bit answer be in val2.w[1]?
future
PostPosted: Fri Jun 25, 2004 7:38 pm     Reply with quote
Running ok.
speed went from ~1070 to ~1500 loops/second.
size down 70bytes.
a sample calculation with old routine equals to 195, new routine 198.
SteveS
PostPosted: Mon Jun 28, 2004 8:25 am     Reply with quote
Yes val2.w[1] - sorry 'bout that.
On the error; the faster way may cause some truncation error. I thought the method I proposed would not cause a problem. I just simulated it on a PC and found no values that differed by more than 1 digit in the answer. Strange. Have you tried a variety of input values to see if the errors are widespread? And what should have been the correct answer?
- SteveS
Futureatwork
PostPosted: Wed Jul 14, 2004 9:28 am     Reply with quote
Hello SteveS,
I (we?) got some more work to do.
int8 interp16(int16 x1, int16 x2, int8 y1, int8 y2, int16 x) {
     int32 n;
     int16 x21,dx,r;
     if (x<=x1) { return(y1); }           // below or equal lower bound
     if (x>=x2) { return(y2); }           // above or equal upper bound
     dx=x-x1;
     x21=x2-x1;
     if(y2<=y1) {                         // negative slope
          r=y1-y2;
          n=dx*r;
          r=n/x21;
          return(y1-r);
          } else {                        // positive slope
               r=y2-y1;
               n=dx*r;
               r=n/x21;
               return(y1+r);
This routine does interpolation in 8bits based in 2 16bit values.
It works fine but I think it deserves some optimization if possible.
Almost all the time is lost in īnī and īrī calculation.
Page 2 of 2
