hiromasakoh
Need CAN Bus source code or example for 18f452 |
Posted: Wed Jun 16, 2004 2:36 am |
Hello ....
I need CAN Bus source code or example for 18f452
Thanks for your help
Posted: Wed Jun 16, 2004 4:12 am |
Maybe you could try to do a little work yourself?
This forum has a search engine |
MartyL Guest
Posted: Wed Jun 16, 2004 5:56 am |
The 18F452 does not support CAN. Will you be using an 18F452 with an MCP2515 or an 18F458? |
MartyL Guest
Posted: Wed Jun 16, 2004 7:51 am |
CCS provides these examples and drivers. If you don't have CCS and you're just looking for someone else to do your work then I hope no one answers you. |
hiromasakoh
Posted: Thu Jun 17, 2004 7:41 am |
I use Microchip APP001 board to do my project
and they (Taiwan Microchip) say 18f452 can work CAN bus
but must work with MCP2551...
I had use search engine to search ''CAN " before....but no any
result...so ask this question...
Hope someone has a experience about this...
^____^
Thanks  |
Posted: Thu Jun 17, 2004 11:39 am |
but must work with MCP2551... |
The documentation for the APP001 board is here:
http://www.microchip.com.tw/Workshop%20ZIP%20files/WAP001%20Workshop%20%20Board.zip
If you look at the schematics in MCU.pdf and Com.pdf, they
do not show an external CAN controller chip. They only
show the CAN transceiver chip (MCP2551). Therefore,
I believe they want you to buy a 18F458 chip and put it
in the main socket, instead of a 18F452.
Then you need to write code for it. If you buy the CCS PCH
compiler, you get all their CAN bus driver files. |
hiromasakoh
Posted: Thu Jun 17, 2004 8:09 pm |
Today I ask Taiwan Microchip about this board...they suggetion to use
18F458. they say MCP 2551 is just only CAN Tranceiver .
So....Now I have a all version of CCS Compiler
and I also have a question about Routine of Instraction about CAN
where can find these data ??
Thanks for your helps...
^________^
student: Herry  |
Posted: Thu Jun 17, 2004 9:56 pm |
Here is a list of the CCS example and driver files.
Press Ctrl-F and search for "CAN" to find all files for the CAN bus.
http://www.ccsinfo.com/exlist.shtml
If you have the CCS compiler, look in these two directories for the files:
c:\Program Files\Picc\Examples
c:\Program Files\Picc\Drivers |
mkent
Posted: Fri Jun 18, 2004 12:04 pm |
PCM programmer, You are a gracious gentleman and I thank-you again and again. |
