ICD-S halt/reset problem
cagacug
PostPosted: Tue Jun 08, 2004 10:15 am     Reply with quote
I am using ICD-40 with PCH v 3.187. Everything seems to be working fine accept when I press "halt program" (shift+f5) I got error saying "Could not run program:No response from the ICD data in buffer 08...."
I must reset the MPU in order to continue.
Any idea?
PostPosted: Fri Jun 25, 2004 6:24 am     Reply with quote
If you use the ICD debug interface
don't set the low voltage programming pin to output set it
to input instead.
This sometimes helps if your debugger hangs, when you try to stop
the program from running.
Also don't use the sleep mode, if the controller is in sleep mode,
the debuger can't stop it anymore.
Bye, Bjoern.
cagacug
PostPosted: Sun Jun 27, 2004 3:22 pm     Reply with quote
bingo!
you are great , thank you.
