Marco C. Guest
Problem with constant data table in ROM |
Posted: Fri Jun 04, 2004 9:11 am |
Hello everybody,
Just a simple question on a little piece of code:
int const Genome[10]={1,10,9,10,2,1,9,10,2,1};
void build(int genomeBuffer[]) {
printf("Hello World \n\r");
void main () {
build(Genome);
the result on a terminal is 64X "Hello World" like this:
Hello World
Hello World
Hello World
Hello World
Why ?
Thank you for answering !
Marco. |
Posted: Fri Jun 04, 2004 11:07 am |
The most likely cause of your problem is:
You have the Watchdog Timer enabled in your #fuses statement,
but you're never re-starting it. So it times out and resets the PIC,
which causes the message to be displayed over and over again.
Your fuses statement might look like this:
#fuses XT, NOPROTECT, WDT, BROWNOUT, PUT, NOLVP
Change it to be this:
#fuses XT, NOPROTECT, NOWDT, BROWNOUT, PUT, NOLVP
An additional note:
You are letting your program fall off the end of main().
The compiler puts a hidden Sleep statement there.
If you're using a hardware USART, the Sleep instruction will
put the PIC to sleep before the last two characters in your
text string are transmitted. The last 2 chars will be not be displayed.
Fix this by putting a while(1) statement at the very end of main():
main()
build(Genome);
while(1); // Add this line
Some tips on asking for help on this board:
When you post a program, you should always post all
of the CCS directives, such as the #fuses statement,
the #use delay statement, etc. It helps us to solve
your problem for you. If you don't post it, we have
to do "mind reading". We have to do that a lot on
this board. Also, your post subject could be better.
More like: "My program displays same message over and over".
Or: "My program constantly re-starts" |
