willie.ar
| need 1 Kb of RAM |
Posted: Sun Jun 06, 2004 7:49 pm |
I want to add RAM to a project. I need to buffer about 600 bytes so I need 1Kb of RAM and I can't find any serial (I2C) static RAM of that size, not either a vendor of the PCF8570. I want to use a PIC because I have all the code almost finished, the compiler, programmer, etc. Does anybody have an idea which configuration of microcontroller and RAM can I use?
tks |
Kenny
Posted: Sun Jun 06, 2004 8:33 pm |
| Quote: | | I want to add RAM to a project. I need to buffer about 600 bytes so I need 1Kb of RAM. |
You didn't say what PIC you're using.
If you're using a 16F877, then change to a 18F452.
Move from 368 bytes of ram to 1536 bytes. There's your 1K.
It's cheaper, too. |
willie.ar
Posted: Tue Jun 08, 2004 9:40 am |
thanks for your answers.
The project is running now buffering 50 bytes on a 16F628 so the 18F452 seems to be "so much" for that task.
the FM24C16 looks to be very interesting. I have to study the protocol to r&w, timing and availability on the market.
tks again
willie.ar |
| FM24C16 |
Posted: Tue Jun 08, 2004 11:06 am |
| The FM24C16 is a drop in replacement for the standard 24C16 EPROM the only difference being there is no wait time required after writes. I used the 24c16 driver and removed the wait after write delays. |
