Vlad
| Need help with RS232 |
Posted: Tue Jun 01, 2004 12:01 pm |
I am trying to connect PIC using RS232 to a PC (using HyperTerminal to read from the PIC (18F452)).
The problem is that no matter how I set the parity and data bits with #use RS232 and no matter how I set the HyperTerminal I keep getting wrong characters in HT window. I am reading characters from the keypad and sending them to both the LCD and HyperTerminal to make sure they are the right ones. I have RxD, TxD, GND lines from PC connected to my PIC. I am only attempting transfer from the PIC for now.
Here is the code:
#include <18F452.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT,WDT128,RC_IO, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600, XMIT=PIN_A0, RCV=PIN_A1, PARITY=N, BITS=8)
while(true)
k = Key_Read() ;
if(k=='*') LCD_Clear(1);
else if (k=='#') LCD_Clear(2);
LCD_Write(k); // send character to LCD
putc(k); // send character to PC
Characters appear fine on the LCD but in HT I am getting wrong chars. For example instead of '7' i am getting an arrow down, for '8' it erases the line etc.
Thanks,
Vlad |
Posted: Tue Jun 01, 2004 12:30 pm |
| Quote: | | I have RxD, TxD, GND lines from PC connected to my PIC. |
You're not using a MAX232 chip, and you're using a soft USART.
Then you need to use the INVERT option in your #use rs232
statement. You should also use a series resistor on the RS232
Rx pin on your PIC. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=19062 |
Vlad
Posted: Tue Jun 01, 2004 2:30 pm |
Thank you!
It worked. No MAX232, so I needed that INVERT.
Thanks again,
Vlad |
