problem with expression & constant
mirberti
PostPosted: Tue Jun 01, 2004 2:41 am     Reply with quote
I write this code but when I compile it, the compiler return me an error :
"EXPRESSION MUST EVALUATE TO A CONSTANT"
why ?? how can I resolve this problem ??
Thanks Mirko
int const PortaI[] = {PIN_B0, PIN_B1, PIN_C2, PIN_B5};
   for (i=0;i<N_INGRESSI+1;i++){
      if( input(PortaI[i]) ) Ingressi[i] = 0x01;
      else Ingressi[i] = 0x00;
Re: problem with expression & constant
PostPosted: Tue Jun 01, 2004 5:42 am     Reply with quote
mirberti wrote:
Thanks Mirko
Basically, the 'input' statement (and the equivalent output one), are not normal functions. They are instructions to the compiler to access a single pin, which must not change after compile time. The compiler cannot handle these funtions receiving anything other than a fixed value. Though the individual values in your array are fixed, by selecting using a variable, you are exceeding what the compiler can do with these functions.
There are a huge number of solutions. Probably the simplest, is just to use a switch to access the required pin. Alternatively, you can just write your own I/O function using a mask (but in your case, since the required locations are on two ports, this involves more work).
mirberti
PostPosted: Tue Jun 01, 2004 9:42 am     Reply with quote
thanks, but in my old firmwware there was a solution with SWITH.
Now I would write a scalable routine with I can use in all my program only changing a define or a constant.
Regards Mirko
Ttelmah wrote:
mirberti wrote:
Thanks Mirko
PostPosted: Tue Jun 01, 2004 10:19 am     Reply with quote
Regards Mirko
Ttelmah wrote:
mirberti wrote:
Thanks Mirko
The switch solution will still work. Adter all you only have four possible pins to be used.
PostPosted: Tue Jun 01, 2004 11:06 am     Reply with quote
Look at the following thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18233
Mark has posted two functions for output_high and
output_low that let you pass a CCS-style pin number
to the functions as a variable, instead of a constant.
Look for these function names in his post:
my_output_high()
my_output_low()
