32bit struct
mvaraujo
32bit struct
PostPosted: Fri May 28, 2004 7:52 am     Reply with quote
Today I figured out that I can't create a 32bit structure like this:
   struct reg_timestamp
      int day;      : 5;      // dia (1 - 31)
      int month;      : 4;      // mes (1 - 12)
      int year;      : 6;      // ano (0 - 64), simbolizando 2000 a 2064
      int hour;      : 5;      // hora (0 - 23)
      int minu      : 6;      // minutos (0 - 59)
      int seco      : 6;      // segundos (0 - 59)
   } int32 timestamp;
Is that right?
Is the only way to create a 32bit variable and rotate each bit to inside the variable?
Thanks,
Marcus
Neutone
PostPosted: Fri May 28, 2004 8:20 am     Reply with quote
You should be able to get the structure working but it should comile like this does.
Int32 timestamp;
int8 day;
int8 Month;
int8 Year;
int8 Hour;
int8 Min;
int8 Sec;
timestamp=sec;
timestamp+=((int16)Min<<6);
timestamp+=((int32)Hour<<12);
timestamp+=((int32)Year<<17);
timestamp+=((int32)Month<<23);
timestamp+=((int32)day<<27);
Using a structure throughout your program is not going to generate efficient code. Do the conversion to and from the compressed format before and after storage. This is going to run much faster and use less ROM at the cost of a few waisted bytes of RAM.
mvaraujo
PostPosted: Fri May 28, 2004 8:23 am     Reply with quote
Neutone,
Great, simply definitive!
Thanks,
Marcus
