programmiing pic16lf876A with ICD
Urvin
PostPosted: Fri May 28, 2004 1:03 am     Reply with quote
Is it possible to program a pic 16lf876A with an ICDU-40 ??? (I can't find it in the device list of the ICDU-40)
TNX
Haplo
PostPosted: Fri May 28, 2004 3:16 am     Reply with quote
PIC16LF876A is basically the low-power version of PIC16F876A so ICD should support it.
dgb
PostPosted: Fri May 28, 2004 9:32 am     Reply with quote
Hi, i'm just building my projects with 16LF876 and ICD. I have not found any problems programming them. In fact, if I need to program and not to test, that is, with the ICD application, I never select the device but I wait the application detects it. As Haplo says this is only the "low voltage" version of the 16F876. Surely this version correspond to those parts that worked fine at low-voltage factory test.
