HELP : Porting code from PIC16F877 to PIC18F452
Eric Belanger
PostPosted: Wed May 26, 2004 8:21 am     Reply with quote
I was short of ROM space in the F877 so I had to upgrade to the F452... I'm using the PCH V3.200 compiler. I had V3.148 before I upgraded yesterday.
I'm having a hard time with the interrupts. I reduced my code to a simple toggling LED on RA4.
When there is no interrupt function defined (#INT_TIMER0), my MAIN program runs fine. But as soon as I put back a very simple interrupt function, the PIC don't seem to execute the MAIN code...
This code works:
#include "18F452.h"
#FUSES HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP,NOWDT,NODEBUG
#USE FAST_IO(A)
BYTE gbyIntFlag;
Set_TRIS_A( 0b11101111 );
do
Output_Low(PIN_A4);
Output_High(PIN_A4);
void TimeOutTickHandler( void )
gbyIntFlag = 1;
But with the #INT_TIMER0 directive the code doen't work anymore. I'm not even using the interupt function, there is no Enable_Interupts() directive in the code !
#include "18F452.h"
#USE FAST_IO(A)
BYTE gbyIntFlag;
do
Output_Low(PIN_A4);
#INT_TIMER0
gbyIntFlag = 1;
I've been scratching my head on this problem for 2 days... Please help !
Eric
ljbeng
PostPosted: Wed May 26, 2004 9:16 am     Reply with quote
I got this to work ok on my 18f452 board that came with PICC. It flashes the green led and it does interrupt ok.
When I compiled your first listing (3.188), I looked at the assembly and there was an infinite loop caused by the compiler. Look at your lst file and look for the interrupt, there was:
013a goto 013a
I don't know where that came from. I rearranged and used the wizard to come up with the following.
BYTE gbyIntFlag;
#INT_TIMER0
gbyIntFlag = 1;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
do
Output_Low(PIN_A5);
Output_High(PIN_A5);
Re: HELP : Porting code from PIC16F877 to PIC18F452
PostPosted: Wed May 26, 2004 9:25 am     Reply with quote
This code works:
#include "18F452.h"
#USE FAST_IO(A)
BYTE gbyIntFlag;
do
Output_Low(PIN_A4);
gbyIntFlag = 1;
#include "18F452.h"
#USE FAST_IO(A)
BYTE gbyIntFlag;
do
Output_Low(PIN_A4);
#INT_TIMER0
gbyIntFlag = 1;
Eric
Did it work on 3.148?. Seriously, treat anything 'newer' than about 10 compiler versions ago, as a 'beta'. There are some really major problems with the compiler at present. Pull down 3.190, and try with this...
The code generated with 3.148, runs fine on my ICE, and happily toggles the A4 pin - big caveat here, you _must_ have a pull-up resistor on A4, it is an open collector output...
PostPosted: Wed May 26, 2004 9:45 am     Reply with quote
Thanks guys for those fast replies...
I've been working with PIC's for the past 10 years, and YES there is a pull up on RA4 ! I agree this is a common error for beginners...
I tried to compile thsi code with V3.191. Doest not do any better. The RA4 output does not toggle:
#include "18F452.h"
#USE     FAST_IO(A)
BYTE gbyIntFlag;
#INT_TIMER0
   gbyIntFlag = 1;
   Enable_Interrupts(INT_TIMER0);
   Enable_Interrupts(GLOBAL);
   do
      Output_Low(PIN_A4);
As mentionned previously, it does work either with 3.200
If you get RA4 toggle with this code, please send the HEX file, I would like to try it directly. Maybe I have one on those old F452 with one of those hardware issues ... ;)
Eric
Eric Belanger
PostPosted: Wed May 26, 2004 9:51 am     Reply with quote
My chip has the folowing inscriptions : PIC18F452-I/PT 04033AE
Eric
eric_belanger@hotmail.com
PostPosted: Wed May 26, 2004 10:08 am     Reply with quote
Eric
Try the simple expedient, of adding some delays.
You may be hitting the read_modify_write problem at the speed that A4 is being driven. You don't mention the clock rate (except in using HS, which implies >4MHz), but given that A4's input is a schmidt trigger buffer, the pull-up, would need to be a very low value, even if the board capacitance is only a few pF. Try something like:
   do
      Output_Low(PIN_A4);
      delay_cycles(10);
      delay_cycles(8);
bele2009
PostPosted: Wed May 26, 2004 10:24 am     Reply with quote
Sorry, but it does not work either.
The pull-up is 560 Ohms. I checked with a scope on RA4 and all I see is a flat line...
Who ever tought a simple thing like that could be so frustrating !
Eric
ljbeng
PostPosted: Wed May 26, 2004 12:28 pm     Reply with quote
This is definately pulsing A4. And interrupting.
#include <18F452.h>
#device ICD=TRUE
#device adc=10
#use delay(clock=20000000)
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#zero_ram
#use fast_io(a)
BYTE gbyIntFlag;
#INT_TIMER0
gbyIntFlag = 1;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
do
Output_Low(PIN_A4);
:020000040000FA
:0400000052EF00F0CB
:08000800FFFF056ED8CF06F0E2
:10001000E950076EEA50086EE150096EE2500A6E30
:10002000D9500B6EDA500C6EF350146EF450156EFE
:10003000E0500D6E000100500F6E0150106E025026
:10004000116E0350126E0450136EF2AA2BEF00F0E3
:10005000F2B44CEF00F00F50006E1050016E1150D2
:10006000026E1250036E1350046E0D50E06E0D8E32
:100070000750E96E0850EA6E0950E16E0A50E26ED0
:100080000B50D96E0C50DA6E1450F36E1550F46E9E
:10009000055006C0D8FF1000FFFF010E176EF29446
:1000A0002BEF00F0FFFFF86AD09E0D8EF20E006E6F
:1000B000060E016EEA6A020EE96EEF6AE92AD8B40A
:1000C000EA2A002E5DEF00F0012E5DEF00F0EA6AF3
:1000D000E96A060EC16E860EC16EC19CC250380B15
:1000E000C26E9698C69A949A94889496000EC66E9C
:1000F000C76ED190800ED56EEF0E926ECD6A000E57
:10010000016ECA6E000ECB6EB150480BB16EF28A12
:10011000C00EF212899889888AEF00F08EEF00F005
:020000040030CA
:0E00000000220C0E000101000FC00FE00F40A7
:00000001FF
;PIC18F452
P.S. I just edited to add the fast_io line.... still works.
bele2009
PostPosted: Wed May 26, 2004 12:59 pm     Reply with quote
I just programmed your HEX data with MPLAB and it works. With my custom programmer it does not. So I think we found the problem... Smile
So back to the drawing board for the programmer before complaining about the compiler and the chip !
I'll fix that and everything sould be ok then (I hope)
Eric
