extern command
hundil
extern command
PostPosted: Mon May 24, 2004 3:16 am     Reply with quote
Hiii to everybody,
I have a problem and will be happy if you help me solve.
I have two files. Name of one of both is main1.C
The other file is (let's suppose that) A.C file
I put #include <A.C> directive in the main1.C.
In A.C file,
I write int MSG, .... command in the A.C file.
(MSG is a variable)
If I define (for example) MSG=1 in the A.C file
The compiler recognizes MSG as an integer in the A.C file
with a value of =1, It is OK.
But, the value of MSG can not be read as (=1) in main1.C
so I can not use it in main1.C
I mean, the value of MSG (1) is not transferred to the main1 file.
I can not use it in main1 file.
Is there any solution for that problem urgently
Is there any command in CCS C like "... extern...."
thanks in advance.
hundil
Haplo
PostPosted: Mon May 24, 2004 3:30 am     Reply with quote
Make sure MSG is defined as a global variable (out of all the function bodies) in A.C file.
And it is better to use #include "A.C" instead of #include <A.C>.
