WDT reset
Suus
WDT reset
PostPosted: Tue May 11, 2004 1:56 am     Reply with quote
how can I check if there's been a watchdog reset?
Susan
Haplo
PostPosted: Tue May 11, 2004 2:10 am     Reply with quote
There is a function called restart_cause() that gives you the reason for reset. As for the values it returns, quoting from the manual: A value indicating the cause of the last processor reset.The actual values are device dependent. See the device .h file for specific values for a specific device. Some example values are: WDT_FROM_SLEEP, WDT_TIMEOUT, MCLR_FROM_SLEEP and NORMAL_POWER_UP.
RKnapp
PostPosted: Fri May 14, 2004 9:51 pm     Reply with quote
Yes -- however, if you're using the debugger, it will always show that the restart cause is "normal power up." Not sure why... Just something to watch out for...
Smile Robert
MGP
PostPosted: Mon May 17, 2004 1:48 pm     Reply with quote
Smile Robert
Probably because the debugger drives the MCLR line to the target PIC low. That would look like a "normal power up" reset to the PIC and would be reflected in the target PIC status bits. That's just a guess on my part, but it seems logical.
