SIOW download software
SteveS
PostPosted: Sat May 08, 2004 3:59 pm     Reply with quote
I'm working with the bootloader (loader.c) that comes with CCS. It basically works and I can download via Hyperterm. However, when I try to use SIOW and the Download Software command it doesn't work. I select the hex file and after that a window comes up, progress bar shows one line has downloaded, and then I get a timeout error. If I log the session it does show one line transferred and the 'ACK' reply from the PIC; and that's it.
Search of the archive seems to indicate a few people have used it successfully; any ideas?
Thanks,
SteveS
Kasper
PostPosted: Wed May 12, 2004 7:37 am     Reply with quote
if you did not include the bootloader.h file, then your hex file may overwrite parts of the bootloader, if it is not write protected.. at least that seemed to be to blame when I was toying with it first.
#include "bootloader.h"
SteveS
PostPosted: Wed May 12, 2004 11:22 am     Reply with quote
I can't seem to locate a "bootloader.h".
The "ex_load.c" doesn't seem to include anything else. Am I missing something?
- Steve
Kasper
PostPosted: Wed May 12, 2004 1:08 pm     Reply with quote
I hope CCS does not give me too much trouble for posting the content here
#define LOADER_END  0x4FF
#define LOADER_SIZE   0x3FF
#ifndef _bootloader
   #build(reset=LOADER_END+2, interrupt=LOADER_END+8)
   #org 0, LOADER_END {}
include this in your project file and it should be OK
SteveS
PostPosted: Thu May 13, 2004 7:01 am     Reply with quote
Thanks - I'll give that a try. Still don't understand why I don't have that code already - I'm at V3.182.
- Steve
Haplo
PostPosted: Thu May 13, 2004 8:30 am     Reply with quote
And I remember in Loader.C it mentions something about setting your buffers to the lowest possible values or some byte may be missed. This may be related to the problem you are seeing.
SteveS
PostPosted: Fri May 14, 2004 6:41 am     Reply with quote
Actually it worked with Hyperterm (and w/o changing the buffers). SIOW doesn't appear to have a buffer setup option.
In any case, I haven't had a chnace to try any sugsetions yet. I realized last night that loader.c puts code at the top of flash. On the 18F parts don't we want to use the bottom of flash so we can take advantage of the boot block protect? So I'm altering loader.c to do that.
Stay tuned...
- SteveS
