Problem with MPLab V6.50 and PCH V3.163
zs6cey
PostPosted: Sat May 08, 2004 12:25 pm     Reply with quote
Hi All,
When I compile my project in MPLab, I get the following error:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\PICC18\Ccsc.exe" main.c +FH
No Errors
Halting build on first failed translation as user preferences indicate.
BUILD FAILED: Sat May 08 19:51:02 2004
PCH has compiled all the files correctly, but MPLab reports the build failed and will not allow me to debug the program.
Any ideas?
Andy
prwatCCS
PostPosted: Sun May 09, 2004 5:25 pm     Reply with quote
Is MPLAB looking for the include files in the right place ? As I recall you have to setup paths from within MPLAB as well as CCS.
Peter Willis
Development Director
Howard Eaton Lighting Ltd UK
zs6cey
PostPosted: Mon May 10, 2004 6:08 am     Reply with quote
I have found the problem Laughing . When using MPLab, I used the CCS Compiler tool instead of the CCS 12/14/16/18 cpomiler tool option. I then browsed to point at the PCH compiler. Then all compiled correctly.
Andy
