Port B Digital Input
AK
PostPosted: Fri May 07, 2004 6:50 am     Reply with quote
I am using a PIC16F876. Pin B1 and B2 are being used for RS232. Can I still use the input_b() function or is that a bad idea. I have a rotary switch connected to Pins B3 through B7 and I would rather not check each pin individually. Thanks for the input.
AK
Haplo
PostPosted: Fri May 07, 2004 7:02 am     Reply with quote
It should be ok to use that function. In a software I2C, the pins are normal IO pins.
