non stop timer????
nfs
non stop timer????
PostPosted: Thu May 06, 2004 5:46 am     Reply with quote
i fixed the following timer to count 20000 times of 100µs the once
the timer still in function over the time configured.
what's the matter?
#include <16F876.h>
/* Set configuration bits in the PIC processor */
#fuses XT, NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
//crystal, no watchdog timer, no low programming, no powerup timer, noprotect=memory protection off
#device adc=10
#device *=16
#use delay (clock=4000000)      /* sets appropriate compiler constants 1µsecond instruction cycle */
#use standard_io ( a )
#use standard_io ( b )
#use standard_io ( c )
#define led1 PIN_A1   //led jaune commutateur '0'
#define led2 PIN_A2   //led verte commutateur '0'
#define led3 PIN_A3   //led rouge commutateur '0'
#define led4 PIN_A5   //led jaune commutateur 'R'
#define led5 PIN_B0   //led verte commutateur 'R'
#define led6 PIN_B1   //led rouge commutateur 'R'
#define led7 PIN_B2   //led jaune commutateur '+'
#define led8 PIN_B3   //led verte commutateur '+'
#define led9 PIN_B4   //led rouge commutateur '+'
#define led10 PIN_B5   //led jaune commutateur '-'
#define led11 PIN_B6   //led verte commutateur '-'
#define led12 PIN_B7   //led rouge commutateur '-'
#define Vpp     1024     //seuil maxi de tension
#define Vppfluct 1003   //seuil autorisé de fluctuation de la tension
#define Vppmin   973    //seuil pour lequel la tension est passée du niveau haut à un niveau plus bas*****
#define Vss    0       //seuil minimal de tension
#define Vctq   921     //seuil de chute de la tension
#define tension_maxi_touche_0    34
#define tension_mini_touche_0    0
#define tension_maxi_touche_R    790
#define tension_mini_touche_R    750
#define tension_maxi_touche_plus    523
#define tension_mini_touche_plus    463
#define tension_maxi_touche_moins    287
#define tension_mini_touche_moins    245
#define txPC   PIN_C6
#define rxPC   PIN_C7
#use RS232(BAUD=9600,BITS=8,XMIT=PIN_C6,RCV=PIN_C7)
#bit ADFM_BIT=0x9F.7
#bit PCFG3_BIT=0X9F.3
#bit PCFG2_BIT=0X9F.2
#bit PCFG1_BIT=0X9F.1
#bit PCFG0_BIT=0X9F.0
#byte INTCON = 0x0b //registre des interruptions
#byte PIE1 = 0x8c   //registre contenant les autorisations d'interruptions
#byte PIR1 = 0x0c
#byte ADCON0 = 0x1f  //registre du convertisseur
#byte ADCON1 = 0x9f  //rôle des pins+justification du resultat de la conversion
#byte ADRESH = 0x1e
#byte ADRESL = 0x9e
#byte port_b = 0x06
#byte port_c = 0x07
#bit GO_DONE = ADCON0.2
#bit ADON = ADCON0.0
#bit ADIE = PIE1.6
#bit ADIF = PIR1.6
#define SET_TRIS_A = 0b00001; // PORTA  AN0 entrée et les autres en sortie
#define SET_TRIS_B = 0x00; // PORTB en sortie
#define TMR1IE = PIE1.0
#define TMR1IF = PIR1.0
int16 us;
int16 ADCvaleur;
int1 wait=true;
int16 Counter=20000;
#int_TIMER2
TIMER2_isr()
     if (Counter)
      Counter--;
     wait=true;
void InitialiseADC ()
setup_port_a( RA0_ANALOG );
setup_adc( ADC_CLOCK_DIV_8 );
set_adc_channel( 0 );
 void main( void )
    long ADCvaleur;
      OUTPUT_B(0x00);// clear all pins on port b
      ADCON0=0x81; // fosc/32, RA0, a/d off, a/d operating
      ADCON1=0x8E; // an0 is a/d input, rest port a digital, internal ref, right justified
      INTCON=0xc0; // enable global interrupts and peripherals
      InitialiseADC();
      output_high (led1);
      output_high (led4);
      output_high (led7);
      output_high (led10);
      delay_ms(400);
      if (ADIF ==1)
      ADIF = 0;
      ADCvaleur = 0;
      while (wait)
            setup_timer_2(T2_DIV_BY_4,5,5);
            ADCvaleur=read_ADC();
               if (ADCvaleur>Vctq)
                  output_low (led2);
                  output_low (led3);
                  output_low (led5);
                  output_low (led6);
                  output_low (led8);
                  output_low (led9);
                  output_low (led11);
                  output_low (led12);
                  output_low (led1);
                  output_low (led4);
                  output_low (led7);
                  output_low (led10);
                  delay_ms(400);
                  output_high (led1);
                  output_high (led4);
                  output_high (led7);
                  delay_ms(200);
                  if ((ADCvaleur<=tension_maxi_touche_0) && (ADCvaleur>=tension_mini_touche_0))
                     output_low (led3);
                     output_low (led1);
                     output_high (led2);
                     output_low (led4);
                     output_low (led5);
                     output_high (led6);
                     output_low (led7);
                     output_low (led8);
                     output_high (led9);
                     output_low (led10);
                     output_low (led11);
                     output_high (led12);
                  if ((ADCvaleur<=tension_maxi_touche_R) && (ADCvaleur>=tension_mini_touche_R))
                     output_low (led4);
                     output_low (led6);
                     output_high (led5);
                     output_low (led1);
                     output_low (led2);
                     output_high (led3);
                     output_low (led7);
                     output_low (led8);
                     output_high (led9);
                     output_low (led10);
                     output_low (led11);
                 if ((ADCvaleur<=tension_maxi_touche_plus) && (ADCvaleur>=tension_mini_touche_plus))
                     output_low (led7);
                     output_low (led9);
                     output_high (led8);
                     output_low (led1);
                     output_low (led2);
                     output_high (led3);
                     output_low (led4);
                     output_low (led5);
                     output_high (led6);
                     output_low (led10);
                     output_low (led11);
                 if ((ADCvaleur<=tension_maxi_touche_moins) && (ADCvaleur>=tension_mini_touche_moins))
                     output_low (led10);
                     output_high (led11);
                     output_low (led12);
                     output_low (led1);
                     output_low (led2);
                     output_high (led3);
                     output_low (led4);
                     output_low (led5);
                     output_high (led6);
                     output_low (led7);
                     output_low (led8);
                     output_high (led9);
                        output_low (led10);
                        output_low (led11);
                        output_low (led1);
                        output_low (led2);
                        output_high (led3);
                        output_low (led4);
                        output_low (led5);
                        output_high (led6);
                        output_low (led7);
                        output_low (led8);
                        output_high (led9);
nfs
Haplo
PostPosted: Thu May 06, 2004 6:02 am     Reply with quote
Your while loop is still incorrect. Look at the code I posted for you earlier to see what I am talking about:
http://www.ccsinfo.com/forum/viewtopic.php?p=26270&highlight=#26270
