16F876 and Bootlader
frustrated Beginner
PostPosted: Fri Apr 23, 2004 3:45 am     Reply with quote
Question
I have trouble with the bootloader for the 16F876.
I can't get them to work.
I try to use the www.microchipc.com bootloader, but it seems that the downloader programm isn't able to find the pic.
I use the 20Mhz 19200baud hex-file but i can't get them to work.
Has anyone an idea?
I#m a PIC-Beginner and
I'm frustrated....
Regards
ckielstra
PostPosted: Fri Apr 23, 2004 11:42 am     Reply with quote
You will have to provide us with more information before we are able to help you.
I assume you are using the PIC16F876? And you are sure it is running at 20MHz?
What tools did you use to program the initial bootloader in the PIC?
Is your PIC running on a standard development board we might know of, or is it your own development?
How is the PIC connected to your computer.
What exactly is working, and what part not?
etc, etc, etc.
frustrated beginner
PostPosted: Mon Apr 26, 2004 11:10 pm     Reply with quote
at first, i got it to work !
i use a millennium board with a pic 16f876
at 20 Mhz and 19200bps.
I only got it to work at 4 Mhz and 9600bps.
Smile
and now i'm trying to make it run with 20 Mhz and 19200bps..
regards
beginner
lucky
18452 Bootloader
PostPosted: Tue Apr 27, 2004 3:48 am     Reply with quote
Me too. I use this bootloader for the 18F452 & found that it would only work 100% of the time at 2400.
At 9600 it would work the first time but never a second time. I think it is to do with the Xon Xoff because @ 2400 it is so slow it works just as well without Xon Xoff.
If you solve this please let us know.
Lucky
www.mpic3.com - MPIC3 player project, Forum, Downloads, Online Shop
frustrated beginner
i solved it
PostPosted: Thu Apr 29, 2004 11:23 pm     Reply with quote
i got the bootloader running at 20Mhz and 19200bps.
I used the asm file and changed it to 20Mhz and 19200bps.
I compiled the file and burned it into the pic.
And it works great Smile
It is so fast.
Mfg
Beginner
