Example File EX_BOOTLOADER.C in PCM Version 3.188
Frank_B
PostPosted: Wed Mar 31, 2004 12:28 am     Reply with quote
I try to understand the bootloader from EX_BOOTLOADER.C for a 16F876 Chip.
The bootloader jumps to 0x200 for the real user application, the global interrupt routine jumps to 0x204.
So the program to download should have a rom offset of 0x200. So it should start at position 0x200 and its interrupt routine should be at 0x204.
How can I make the compiler to offset the code correctly ?
Frank
guest
see ... EX_BOOTLOAD.C
PostPosted: Wed Mar 31, 2004 9:38 am     Reply with quote
not
EX_BOOTLOADER.C
Frank_B
PostPosted: Thu Apr 01, 2004 3:11 am     Reply with quote
ok, the EX_bootload is the user-aplication.
But when adding a interrupt-function like
#int_RDA
RDA_isr()
putc('X');
there is a "invalid ORG range" error.
