literal values in PIC regs
asjad
PostPosted: Tue Mar 30, 2004 8:36 am     Reply with quote
I am trying to set bits on specific values in the PICs registers:
using a 16F84
#define STATUS 0x03 //0x03 is the address of status on the PIC
I try to do the followng but get an error:
"bit_set(STATUS,5);" //select bank 1
ANY IDEAS????
Best Regards
PostPosted: Tue Mar 30, 2004 11:32 am     Reply with quote
bit_set() operates on a memory location or register.
You're giving it a constant. You need to use the #byte
directive to declare STATUS, instead of #define.
