jefft
| Accessing struct byte by byte |
Posted: Wed Mar 17, 2004 11:49 am |
I have seen several threads on the forum addressing this same problem, but none of their solutions seem to work for me. I have a simple struct that I would like to access byte by byte (for the purpose of transmitting it). It seems to me that I should just be able to access the fifth byte by
my_struct[4]
but that doesn't work (it always returns 0). It also seems like:
int8 *ptr;
ptr = (int8 *)my_struct;
ptr+=4;
fifth_value = *ptr;
should work, but that doesn't either (also giving 0 as the value).
The specific struct I have been using for testing is:
struct t_t {
int t1;
int t2;
int t3;
int t4;
int t5;
int t6;
and I have initialized all of the variables in the struct to 1.
Thanks! |
Posted: Wed Mar 17, 2004 12:00 pm |
Use a union of your struct and a byte array. See below.
The following program displays this on the terminal screen.
1 2 3 4 5 6
1 2 3 4 5 6
| Code: | #include <16F877.h>
#use delay(clock = 4000000)
union
char tt_array[6];
struct t_t {
int t1;
int t2;
int t3;
int t4;
int t5;
int t6;
}tt_struct;
}tt_union;
char i;
// Initialize the values.
tt_union.tt_struct.t1 = 1;
tt_union.tt_struct.t2 = 2;
tt_union.tt_struct.t3 = 3;
tt_union.tt_struct.t4 = 4;
tt_union.tt_struct.t5 = 5;
tt_union.tt_struct.t6 = 6;
// Print structure elements
printf("%d ", tt_union.tt_struct.t1);
printf("%d ", tt_union.tt_struct.t2);
printf("%d ", tt_union.tt_struct.t3);
printf("%d ", tt_union.tt_struct.t4);
printf("%d ", tt_union.tt_struct.t5);
printf("%d ", tt_union.tt_struct.t6);
printf("\n\r");
// Print array elements
for(i = 0; i < 6; i++)
printf("%d ", tt_union.tt_array[i]);
