help me in LCD
mohee
help me in LCD
PostPosted: Wed Mar 17, 2004 8:29 am     Reply with quote
hi Laughing
im new in programming with PCM. so im working in my project and i use LCD and PIC16F877, my problem is to let the cursor move at first char of each word when "next" bottom pressed , and if pressed enter call some function and another bottom "back" make the cursor to back at first char of each word
so please help me Crying or Very sad Crying or Very sad Crying or Very sad
chava
let me anderstand
PostPosted: Wed Mar 17, 2004 4:10 pm     Reply with quote
Let me anderstand...
your problem is the LCD or the algorithm to do what you want to do?
mystery
Lcd
PostPosted: Wed Mar 17, 2004 5:07 pm     Reply with quote
If you want to do this action you will have to find or program your
own lcd driver.
If you search on your C drive for "lcd.c", this is a basic lcd driver provided
by ccs.
This ccs driver does not support cursor to flash!!!!!
dyeatman
LCD code
PostPosted: Wed Mar 17, 2004 5:20 pm     Reply with quote
Depending on what display is being used, the character flash has nothing to do with the driver as it is usually initiated by a simple ascii code/character sequence. However, the display may not even support flash at all. They have to look at the display data sheet to find out what is required, or if it is possible....
Re: let me anderstand
PostPosted: Thu Mar 18, 2004 3:07 am     Reply with quote
my problem is in the algorithm to do what i want to do.
mohee
PostPosted: Thu Mar 18, 2004 3:49 am     Reply with quote
my problem in the algorithm as below:
#if defined(__PCM__)
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#include <lcd.c>
char k;
lcd_putc("Hello Mohee\n");
lcd_putc("Thanks God ");
while(true)
if( !input(PIN_A1) )
lcd_gotoxy(7,1);
lcd_send_byte(0,0x0F);
delay_ms( 2 );
if( !input(PIN_A4) )
output_B(0xff);
delay_ms( 2 );
lcd_gotoxy(1,2);
if( !input(PIN_A2) )
lcd_gotoxy(1,2);
output_B(0x0f);
when i test this code on PIC doesnt work as i expect, i see that the cursor flashing on two char s.
so what is you say in this ...... chava Wink Wink
