cura
| Connecting two PIC16F84A using RS-232 |
Posted: Sat May 27, 2006 5:58 am |
Is it possible to connecto two 16f84a using the rs-232 protocol? I'm trying to do it but what I get is that there is no transmission/reception.
I want to use a single wire (in one pic as rx channel, in the other as tx channel).
Is there any place where I can find an example of this two PIC connection?
THANK YOU! |
Humberto
Posted: Sat May 27, 2006 7:25 am |
You can do it connecting Tx pin of one PIC to the Rx pin of the other PIC directly.
| Quote: |
Humberto |
Mark
Posted: Sat May 27, 2006 8:25 am |
| Ever think that maybe your code might be the problem? Post what you have and make sure that you use the "Code" button. |
cura
Posted: Sat May 27, 2006 9:31 am |
This is the code, it is just a remote control for 10 channels. What I want that the Rx PIC copies exactly the channel configuration in the Tx PIC.
For the Rx PIC
#case
#include <16F84A.H>
#include <defs_f84.h> // registers and bits
#include <STDLIB.H>
#fuses xt,nowdt,put,noprotect
#define RS232_XMIT PIN_A1 //Pin de transmision
#define RS232_RCV PIN_A1 // Pin de recepcion (sera el mismo que transmision)
#use delay(clock=4000000) // 4 MHz OSC
#use rs232(baud=1200,xmit=NULL, rcv=RS232_RCV)
int canales[2];
void main(void) {
trisa1=1; //Receiving Pin
trisb0=0;
trisb1=0;
trisb2=0;
trisb3=0;
trisb4=0;
trisb5=0;
trisb6=0;
trisb7=0;
trisa2=0;
trisa3=0;
trisa0=0;
//Setting Channels
output_low(PIN_B7);
output_low(PIN_B6);
output_low(PIN_B5);
output_low(PIN_B4);
output_low(PIN_B3);
output_low(PIN_B2);
output_low(PIN_B1);
output_low(PIN_B0);
output_low(PIN_A3);
output_low(PIN_A2);
while(1){
canales[0]=getchar();
canales[1]=getchar();
if(bit_test(canales[0], 0)){
output_high(PIN_B7);
else output_low(PIN_B7);
if(bit_test(canales[0], 1)){
output_high(PIN_B6);
else output_low(PIN_B6);
if(bit_test(canales[0], 2)){
output_high(PIN_B5);
else output_low(PIN_B5);
if(bit_test(canales[0], 3)){
output_high(PIN_B4);
else output_low(PIN_B4);
if(bit_test(canales[0], 4)){
output_high(PIN_B3);
else output_low(PIN_B3);
if(bit_test(canales[0], 5)){
output_high(PIN_B2);
else output_low(PIN_B2);
if(bit_test(canales[0], 6)){
output_high(PIN_B1);
else output_low(PIN_B1);
if(bit_test(canales[0], 7)){
output_high(PIN_B0);
else output_low(PIN_B0);
if(bit_test(canales[1], 0)){
output_high(PIN_A3);
else output_low(PIN_A3);
if(bit_test(canales[1], 1)){
output_high(PIN_A2);
else output_low(PIN_A2);
delay_ms(15);
} // end of main
For the TX PIC:
#case
#include <16F84A.H>
#include <STDLIB.H>
#define RS232_XMIT PIN_A1 //Transmitter pin
#define RS232_RCV PIN_A0
#use rs232(baud=1200, xmit=RS232_XMIT, rcv=NULL)
int canales0;
int canales1;
void read_ch(void){
if (input(PIN_A2)){
bit_set(canales1,1);
if (input(PIN_A3)){
bit_set(canales1,0);
if (input(PIN_B0)){
bit_set(canales0,7);
if (input(PIN_B1)){
bit_set(canales0,6);
if (input(PIN_B2)){
bit_set(canales0,5);
if (input(PIN_B3)){
bit_set(canales0,4);
if (input(PIN_B4)){
bit_set(canales0,3);
if (input(PIN_B5)){
bit_set(canales0,2);
if (input(PIN_B6)){
bit_set(canales0,1);
if (input(PIN_B7)){
bit_set(canales0,0);
void send_data(void) {
putchar(canales0);
delay_ms(50);
putchar(canales1);
void main(void) {
trisa1=0; //tx pin
trisb0=1; // channels
trisb1=1;
trisb2=1;
trisb3=1;
trisb4=1;
trisb5=1;
trisb6=1;
trisb7=1;
trisa1=1;
trisa2=1;
trisa3=1;
while(1){
read_ch();
send_data();
} // end of main
The data will only travel from Tx to Rx, this means that no feedback from the receptor is needed in the transmitter for the application in order to work.
THANKS!!! |
